Removable Harness Bar for DE (only DEs ;)
Does anyone have a harness bar and belt setup that they only use for DEs? I'm getting pretty sore from my single shoulder belt.
My car (2000 996) is a daily driver and I plan on about 6 or 7 DE events a year. I want a "contraption" that I can install/remove each time (and then use the regular belt for daily driving). All of the topics I found discussed serious permanent setups and not a temporary (repeatable) solution.
Thanks in advance,
-td
Thanks in advance,
-td
I think that you need to be more specific as to the time you are looking to spend to remove the bar and harnesses. A Das Sport bar is bolt-in and can be removed in a decent amount of time. You would need to remove the seats to get the bar in/out.
Steve
Steve
Herr Unmöglich
Keep in mind you'll need to have points for you harness ends to snap into, which will likely mean having to pull the seats, add the bar, swap out the buckles for the harness ends, then reinstall the seats.
Either that or come up with some contraption that allows to to concurrently use the same mount point for both the harness end points and the 3 point buckle.
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
If it is side to side motion you are trying to get rid of you could always try a seat upgrade instead. I've found that in leather seats without good side bolsters a harness doesn't help as much as I'd like.
Steve
Steve
To avoid any further confusion, I don't want to install and repeatedly "undo" a permanent harness setup and call that "removable." Rather, I would like input from people that take their DD to DEs and swap in/out a harness bar. Or from people that have harness bars installed, and "know" that they could remove them relatively quickly and easily if they wanted to. And if someone out there actually does do the swap, how long does the drill take?
-td
Well, there are no 30 second solutions, but it looks like the quickest is the BK harness truss, if you leave the rear bar in permanently (see instructions )
For all that, I'd be inclined to bolt in something serious like a DAS bar at the start of the season, and only take it out for the winter.
-td
Not to add additional complication to what you want to be an easy solution, but be certain what you are after is allowed, now and in the future, by the organizations that will be running your track events. In our Region, PCA and Geographic, beginning next year the "harness guide bar" and harnesses that terminate at the rear seat belt mounts, will no longer be allowed. The harnesses will need to terminate close to the seats, either on a full roll bar or on a harness truss bar like Brey-Kraus sells. Terminating the harnesses at the rear mounts, and the resultant long run for the harnesses, has been found to allow as much as 7" of stretch during a hard frontal impact.
You can terminate the lap belt portions of the harness at the same terminals as the three point belts if you get the proper B-K adapters.
Originally Posted by td873
Great idea! BTW- do you CA folks have an off season? We have DEs almost all year round. There's even an event in Houston in December, and one here in Feb...
-td
-td
Glad to help!
I'm not sure if Californians have an off season, but I have a "going skiing instead of trackdays" season!
When I first started DEing, I did so in my 996 C4 Cab with a Brey-Krause harness bar and Schroth belts. You need to change the seat mounting bolts and add the hardware to fasten the belts, but once that's done, the whole contraption is a 10 minute in/out chnage in a cab. Don't know about a coupe, but it was a good way to get started for me, and I didn't have a lot of unsightly stuff in the car when it wasn't being tracked.
I have a DasSport Weekender 4 pt bar, GT3 driver side seat, Recaro Pole Position Passenger side with BK inboard mount point, BK back braces and 6pt Simpson polyester harnesses. I'm debating selling my car and buying a Radical/DSR type car. Give me a PM.
