THill question
THill question
I'm think I'm going to go to the NASA HPDE at Thunderhill on 10/26. Never been on the track and a friend is letting me borrow his car. Not that I plan on running off but what are the run offs like there? The last thing I want to do is damage a friend's car so I'm curious. thanks.
Depending how wet it has been, it could be pretty muddy. There is a good amount of runoff, Only one turn with a wall nearby. I can't speak for the quality of the runoffs because I haven't gone off track there, but I have seen lots of motorcycles go off and be able to ride it out so it can't be too bad.
You are certainly braver then I!
I've gone off most of the turns at Thunderhill. It's a pretty safe place to drive, certainly compared to Laguna Seca or Sears Point. You can hit the wall if you overcorrect on a slide coming out of turn 14, but it's not easy. You can get into trouble if you overcook turn 8 (although that's not generally a problem for newcomers). Turn 3 is an off-camber sweeper with some areas on the inside dirt that can roll a car over. The bypass can roll a car. Turn 9 looks like it can roll a car, but isn't all that bad once you go off.
Broadly speaking, though, Thunderhill is an excellent learning track and a lot of fun. Hank Watts put together an excellent turn-by-turn gude for the PCA GGR, which you can get here.
There's an in-car lap video in my signature, under the 'let's go out for a lap' link.
And here's one with the cyclone.
Your friend's car must be special for you to keep the GT3 at home.
