kumho v710 tire pressures
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
They say 40 psi is too much.
Might have more info after that.
The 36 range jibes with autocrosser reports. The Hoosier 06 tires also take this
range. Hoosier says to run them softer than 05s and previous which did like
40-42psi.
Joe Weinstein
40-42psi.
Joe Weinstein
I was at 37psi hot last year, but that was in a 944. Main thing to watch with 710's is the loss of grip when they use up their heat cycles. Three-four weekends is about it ... 15-20 heat cycles ... and I don't know anyone around here whose V710's survived the winter. But oh boy do they ever stick when they are fresh. :-)
In addition to tire pressure, I have heard that the V710 is designed as an autocross tire as opposed to track tire (implying that it will overheat/not last for more than a lap or 2). Is that the case?
Craig, how does it compare to the V700 victoracers if you had used that before? Both track & longevity?
thanks...
thanks...
Originally Posted by Bigpinekey
Trumper is right. I've been running the 710's on my z06 for a couple of years and they run best for me when I start at 25-26#'s. That gets them to the mid 30's when they are hot and they work real well. Some of the T1 racers even start with less than 25#'s.
I see you have been here a while. Very Good... technical stuff on this site.
The Kumho V 710's are "Road Racing"... DOT... " R " Tires. Some people have used them for auto-cross events.
There ie: when auto-crossing...
cold pressure should be ~ 36 psi.
Your not on the track long enough in auto-cross to heat them up!!!
Trumper, thanks for the insights... that's what I thought as well but since I heard otherwise, I thought I'll ask.
Have you tried the old V700 Victorracer before? How does it compare?
thanks.
thanks.
V710's are subtle in their communication to the driver, and seem to "deaden" steering feel. The tires are not loud communicators. Fortunately, the tires also have a very broad slip angle curve - if one drives like an idiot like I do more often than not, the tires will save/improve results.
When they run out of heat cycles (and they'll do this before they physically wear out), there will immediately be relatively little grip until you get the rubber melting, and even then the grip won't be good. They don't seem to mind autox heat cycles as much - autox'ers seem to be able to get 8 to 10 events out of them.
YMMV, I'm in a 944 S2, pretty much stock except for springs and 250 lbs of safety equipment - including skid plates and mudguards - so my experience may not be typical ...
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
A final note: A competitor in an F-body ran V710's for the first time a couple of weeks ago and experienced a tread splice showing - a common V700 appearance. First time I'd heard/seen about it on a V710, though, and it didn't look pretty. He was, however, almost a second faster in V710's over shaved RA-1's, on a 53 second road course (Shannonville Nelson).
thx all, for the great info.
i too thought the v710 was for autocross use only but i read the reviews on tirerack and there were some vette dudes who used them on the big track with great success and good tire wear. the tirerack guy also said they should last a little longer than hoosier r6s but i'll take it with a grain of salt. i thought i would give them a go so i bought 245/45, 315/35-17s. the fit is good on the 9" wide fronts but the rears are "balloned" on the 10.5" wide rims. i hope they don't feel squirmy. the rears just barely fit under my rolled fenders.
i was going to try them out this weekend at buttonwillow but, alas, mech issues have sidelined me. i'll have to wait til july for the next timetrial event.
I've probably gone through 50 710's, and I've been very pleased with them.
