double clutching
#46
Originally Posted by TD in DC
It is very hard to blip too much, particularly if you have a rev limiter. The larger the blip, the more time you have to release the clutch. The smaller the blip, the greater the chance you will lock the tire up a bit upon release. "Most" drivers do not blip enough. Work on braking smoothly and giving a very healthy blip. Don't worry about letting off the brake a "little" bit. You can't tell that I do it while in the car, but data shows that I do. I have heard that nearly everyone does a little.
I actually heel and toe constantly, or at a minimum rev-match, even during daily driving. I find that it is impossible to drive one way on the street and a different way on the track. The goal is to develop good habits that you perform subconsciously. It is too hard for me to do that unless I am "always" driving the same way.
#47
Originally Posted by Geo
I spent years racing karts which of course require LFB. You'd think I would be used to it and able to use it. For some reason I just cannot bring myself to do it in cars.
#48
Originally Posted by Arrwin
Ah ok...perfect explanation, which leads to my initial question. After I blip to say 4k-5k rpms, should I release the clutch right away @ about 4k rpms or should I wait and release at say 2-3k rpms? My goal is to not have the syncros work or is this not possible?
don't worry about syncros . . . your car is modern enough that they will, for the most part, take care of themselves. Rather, you are worrying about matching the revs so that your car will not be upset by you "chirping" the rear wheels when you downshift, which can throw you into a spin, or at least make the car unstable.
#49
do you guys blip when the stick is in neutral or in the new (lower) gear?
e.g. on a 4 to 3 downshift, do you just brake, clutch in, move to 3rd, blip and release clutch?
or do you actually pause in neutral and then blip and then put stick in 3rd and release?
i do the former and it seems to work fine. Should i be doing the later?
#50
Just like this....
![](http://img454.imageshack.us/img454/7045/ht11268193571pi.gif)
#51
You must get out of the clutch right away since the revs drop very quickly. In other words, blip and immediately out of the clutch. If you wait, you will have wasted all of the work you have done, and possibly made it worse than if you had just shifted without trying to blip at all.
Thanks again!
#52
do you guys blip when the stick is in neutral or in the new (lower) gear? e.g. on a 4 to 3 downshift, do you just brake, clutch in, move to 3rd, blip and release clutch? or do you actually pause in neutral and then blip and then put stick in 3rd and release? i do the former and it seems to work fine. Should i be doing the later?
Read post #51, then watch my video clip again. You declutch. A split second later, the shifter is moved to the intended gear as the throttle is booted. These two happen simultaneously. A split second later, the clutch is re-engaged. It's over in a Mississippi!
#53
The block of wood idea taped to the gas pedal sounds like a good idea to practice on the street.
I can't think of any other way to have the brake and the gas be close enough to make practicing on
the street feasible.
