Had to order 205/50 17's to cure ABS blues...
just don't want the ABS to quit at the Glen. My 205/40 17 Toyo RA1's were causing the ABS light to come on. It was fine and didn't quit at Lime Rock mostly because you don't go straight long enough for the system to see the difference in wheel speed front to back, but I bet at the Glen it won't be fine.
Scott
Scott
Matt, running 255/40 17's rear and 205/40 17's front. According to Vilvan tire I can't get the 225/45 17 because Toyo does not make the RA1 in that size.....
They do make a 235/40 and 235/45 17's.
Checking the Toyo website, I got the following circumferences
205/40 = 23.5 inches
235/40 = 24.4 inches
235/45 = 25.4 inches
255/40 = 25.0 inches
The 205's and the 255's have a difference of 6% - However, the 235/40 and 235/45 both have only a 2% difference than the 255's. I've run the 235/255 setup for years with no ABS issues. The only issue you may run into is that the 235 is a marginal fit on a 7" rim. It fits much better on a 7.5 or 8 inch. If you run on 7's - you may want to add an extra pound or two to the fronts to keep them from rolling over.
I just ordered a pair of Toyo RA1's in the 235/45/17 and 255/40/17's based on a friends experience who's currently running this set up with RS height, not anticipating any problems.
