GTS Challenge at CMP is next.
Hello Racers!
Carolina Motorsports Park
May 6 - 7, 2006
To register, please go to http://www.nasaproracing.com/nasa_ev.../?event_id=360
TRACK LAYOUT > http://www.turn1motorsports.com/imag...diagrambig.jpg
ONE LAP AROUND CAROLINA MOTORSPORTS PARK can be found at > http://www.carolinamotorsportspark.com/
Reminder:
Please review GTS rules carefully including - new for 2006 - a mandated Dyno certification with appropriate form under > 5.0 Determining the lbs/RWHP, torque ratio / or > 5.1 Dynamometer procedures for AWD (All Wheel Drive) Cars / if you have an AWD.
Logbook > you'll get from NASA Mid Atlantic upon Annual Tech inspection if you haven’t done so yet. Tech Form is available at the same time to be filled out first - you can download from NASA's site and bring with you filled out to Tech. All others, just bring your tech form filled out to hand to me.
Dyno Update:
For those of you who came to the GTS races at VIR in February or Shenandoah and handed their dyno forms over, I have made copies and will hand the originals back to you along with dyno printouts. I will simply need to record the info in your current logbooks along with your rollcage number.
Keep in mind also that any car that doesn’t have a certified dyno form for 2006 is automatically bumped to GTSU. No exceptions.
If you’ve come to VIR or Shenandoah and are heading to another regional race before May 6-7, just shoot me an email with your fax number and I’ll be happy to send your dyno info.
I also have an ample supply of GTS decals, should you need any.
We’ll see you at the track!
Olivier Raoust
GTS Challenge Director | Mid Atlantic Region
#711 GTS3 BMW
May 6 - 7, 2006
Reminder:
Dyno Update:
Olivier Raoust
#711 GTS3 BMW
