Pirelli Corsa Failure
Originally Posted by Bob Rouleau
ceboyd - the Corsa is very popular in our region for its combined wet/dry performance. Not known for failures of the type pictured here. Oddly enough we have seen belt failures on MPSC instead. Go figure. I have run through about 10 sets of Corsa with no problems other than they wear out eventually.
Best,
Best,
..NEVEr dry rot issues with MPSC.. and never seen any thread seperation like that either!
Originally Posted by viperbob
I have seen this a number of times with the Corsa. One guy had it happen on a rear a mile from his house. Used his spare, got another half mile and the other rear blew just like yours. Both blew right at the sidewall to the tread. Tires were properly inflated and had plenty of tread. I have also seen them go at track events several times. Every time it was with the 285 tire on the rear.
my rears were 285 that dry rot cracked badly as well with the 1st generation PZero Cs
...also properly inflated.. and at that time ONLY for autocross use (not even DE track use like I do now)
Hmm I wonder if it is size specific? My GT2 used 315 and the GT3 is 295 in back. Hoosiers had a problem with one size tire a few uears back ..hmm.
George
Chris, it didn't. Still trying to get the gearbox together, never got the monoballs on the car, along other stuff. TWS is this weekend and it doesn't look like I'll make it. Oh well, I probably don't need to race it before I get it set up properly.
George
George
Pirelli is going to look at the tire, so it is on its way there. I don't think anything will come of it, as they claim no responsibility if the tire is used on the track. I thought that odd since it is a track tire, but whatever. The replacement is backordered for a couple months. Not sure what to do now.
Bro
Run the P-Zero Corsas for the last 2 years with no issues. Just lucky, I guess.
I've been thinking of going to Hoosiers this year anyway. So, you may have helped make my decision. In any event, I too am very glad that no harm came to you or your car.
Richard
Richard
Originally Posted by George A
Yup, Hoosier had a problem with their 285/30-18, same size, in the back of 911's. Hmmm (again)........
George
George
Ahhh digging this thread up from the dead....
I just came back from a track day that ended much too soon. Prior to mounting the wheels for the track day, I would have guessed that my Corsas had enough rubber for two more DE's. During yesterday's DE, it wore to the cords in just two sessions. The last time I used these tires was back in October '06, and I noticed then that the inside tread blocks had started chunking. Attached are a few photographs. Before mounting on the track wheels, I had about as much tread on the inside blocks as I had in the middle, so you can see that the inside must have just disintegrated.
I run these corsas at ~26 cold, ~33 hot. I also inflate them to 35 cold for the 1.75-hour drive to and from the track. The photo shows a front tire with 6 prior DE days. -3 degrees of camber, 1/8" toe out.
Originally Posted by Big6Dad
Wow, I had the same thing happen to my corsa at Summit Point a few weeks ago. Looked just like the first picture of this thread.
