944 trailing arm weight difference.
Originally Posted by Team SSR
Does anyone know the actual weight difference between the early steel trailing arms and the later aluminum ones?
TIA
TIA
Making the switch to aluminum arms results in increased track, I believe. If so, this would mean you may need to change to late offset wheels to avoid clearance problems.
Others may know better, though
For some reason when I changed my early car to alum. rerar contol arms I had two sets of stub axles one set made the car track to wide for the wheels I had planned on using.
If you desire a wider track I think you need the later control arms or stub axles. not sure on years.
I did this swap on my 944. Swapped the 84 steel rear suspension with the early alumuinum one.
Track was the same. However to do the swap you needed longer 1/2 shafts and spring plate was shaped different where it attaches to the trailing arm. Result was I had get into teh t-bars to change to later spring plate. Plus hard brake lines are different.
The weight for single trailing arms stripped of everything (no stub axles, hubs, bearings, etc) are as follows:
* Steel = 17 pounds each
* Aluminum = 14.5 pounds each
Therefore, you would have a weight savings of 5.0 pounds for a pair of trailing arms.
