993 roll bar choices
Originally Posted by 38D
As another data point, I am do not think that the DAS bar is PCA club race legal.
Mr. Excitement
As another data point, I am do not think that the DAS bar is PCA club race legal. Safety Devices definitley is. Not sure about Autopower.
The issue with the Autopower bars was/is they were using welded seam tubing that has a weld seam runing the length of the tubing. DOM is a better more consistent materal to work with and some sanction bodys rule out seamed tubing.
I think (but don't know for sure) that Auto power has stopped using welded seam tubing. This will not help ypu if you purchase a used one and the group you are racing with disalows it.
Originally Posted by Mark in Baltimore
The DAS bar is definitely legal in PCA CR in a stock, unprepared car. Bump up to prepared and plan on adding a full cage. Check the DAS website.
"Note that roll bars without terminal mounting plates braced on the frame either on or parallel to the floor are not acceptable."
I believe the DAS bar mounts to the side of the front rail, no?
2006 rulebook:
2006 rulebook:
2005 rule book
"The mounting area of bolt-in roll bar/ roll cage must be backed by a plate of a size equal to that of the uppermounting plate with a minimum thickness of 3/16".
I don't have a copy of the 2006 rule book. Can anyone tell me if the language cited by Colin replaced the above language? If so, why? The 2005 language required a 3/16" mounting plate ... and the 2006 just requires a plate? I'm confused.
I can think of severaal guys going to the Sebring CR that will be very surprised if this a really intended to make the DAS bar illegal. I rather doubt it.
PCA Club Racing 2006 Rule Book
The language for roll bars or cages has not changed from 2005, from what I recall. If I'm wrong, someone please refresh my memory.
Wow, what a helpful place... Thanks everyone for raising the questions and for clarifying the answers. Stuff I've never even thought about.
SFreeman, check your PM.
Paul
Paul
