What would you do, call it quits or fight against reason?
#61
Unless I am mistaken, even though PSM kicks in occaisionally when it's turned off, as soon as the event is over the PSM turns back off.
There is no doubt that PSM is not wanted in a track car but it isn't quite the hinderence that most people think it is.
For the understeer issue, the easy first thing to try is air pressures.
#62
Originally Posted by mitch236
Unless I am mistaken, even though PSM kicks in occaisionally when it's turned off, as soon as the event is over the PSM turns back off..
You can't hit the brake and the gas at the same time, therefore, you can't left foot brake.
To clarify, there is an ideal tire pressure that will give the maximum (average) amount of grip. If you go higher than that, or lower than that, you will reduce the amount of grip because you no longer have an "ideal" contact patch. If your car understeers, and you reduce the rear grip by changing the tire pressure, it might be more neutral, but if it was the front tires that were really causing the understeer, then you have given up grip!
For DE, it probably makes no difference, unless like me, you obsess over this stuff For racing this stuff is crucial.
Race tracks are like boat yards. There are many things that people do without really thinking them through because its "common" knowledge.
#63
Race tracks are like boat yards. There are many things that people do without really thinking them through because its "common" knowledge.[/QUOTE]
Boats are like racetracks? Do you think Kam could explain this one to me or will it require a new thread??? Hey your tire temp prob makes a good toothpick.
#64
Originally Posted by TD in DC
Also, I assume what you mean is that trailbraking is fine so long as you keep rotation down to below 7 degrees of slip, which under most circumstances you shouldn't be doing anyway. Is that what you meant?
#65
Originally Posted by Darren
Yes.
For the record, I think PSM is a very useful tool for beginning and intermediate drivers. I only think it might become an issue for advanced-intermediate to advanced drivers. I am glad my car has it (especially since my track car doesn't )
