Does Weaving Warm Tires?
Originally Posted by macnewma
CC-
How violently were you weaving? I have seen the F1 guys get to the point of actually sliding the car back and forth. At the same time, you could get sideways doing it and take out 3 or 4 cars behind you like Danica did at Indy.
A few years ago at Mosport, the black run group was going around on the warmup lap of the first session of the day. On the back straight, the 944 Turbo in front of me started weaving quickly (to heat his tires I guess). Unfortunatly, he lost control and nosed it into the wall. The rest of us just parked in pit lane for 1/2 the run
CC-
MSPC's aren't a very good tire to test for this, since they're already notoriously hard to get to temperature.
Also, IR is a bad method of taking tire temperatures, since it only measures the temperature of the surface of the tire -- which is getting a lot of cooling from the airflow over it. Getting the temperatures for the 'meat' of the tire would be more useful, but it'd be a lot more difficult, since you'd need to post a couple of guys with probe-type pyrometers on opposite sides of a (closed to all but one car) track.
Originally Posted by mitch236
Glad someone did the research that I always thought was true. I only weave to clean the tire surface. Hard braking does more for warming. One thing that weaving does give is information about available grip. If you are racing and coming up towards the last turn before the green flag (on the last straight) weaving violently can give some insight about what's available to use in the first turn.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
What you really care about IS surface temp, but that is a poor measurement after you make it back to the pits. Hence the probe is more reliable for pit measurements.
As others have said, I weave, brake, and accelerate on the pace lap of a race. When in DE/TT conditions I just go out and drive as I have plently of time to get heat into the tires, car, self.
Well, to weave to not to weave...that is the question...I guess. I like to weave to clean the tires as been pointed out by John and Mitch. Where I run, often times, the paddack is loaded with rocks and other debris as well as a hot tire will often pick up unwanted rubber along the way. I find that weaving helps clean the tires. Also, as been said, it does give you a "preparatory feel" for what's happening with the tires. I also like to get on the brakes during the warm up lap always making sure that no one is on my rear, otherwise... Trying to do a full warm up lap, testing the adhesiveness of the tires and the effectiveness of the brakes just makes good sense to me.
Not to high jack this thread, but the Hoosier rep at Road America told me Fikse's are notorious for allowing the tire to spin on the wheel rather easily. Has anyone else had this problem. 3 of my four tires rotated (not mounted at the same time). The scary part is it looked like one of the rears spun under acceleration or went 3/4 of the way around under braking. My car is stock so I seriously doubt I have enough torque to do it under acceleration but the other rear barely moved (or moved 7/8ths of the way around the wheel). Obviously, 3/4 out will cause a vibration. So, anyone?
Oh yeah, I weave to clean them off.
I stopped balancing slicks on the Cup 2 years ago, makes no difference. By the time You make Your first lap on sticky tires they are out of balance due to crud, spin on rim etc...
On the weaving, we sometimes start as low as in the teens on the Cup and it is very important to get at least a lb or 2 of climb prior to takeoff to help at start but they must be low enough to be where You want them late in the game when everyone who started too high is on iceskates. Being in the South we may see a bit more climb due to 100deg F racing environs regularly.
Mark, I look forward to Your thoughts on Heartland after the repave, jumping the Cup at full boogie and landing it ina full broadie to avoid the wall yet get lowest lap time did not sound very attractive to me...yikes.
Originally Posted by Mark in Baltimore
John,
I'm on MPSC's and have never noticed an issue with my FM-10's. Maybe it's related to just the Hoosier/Fikse combo?
I had MPSC rotate on my front FM-10's about 1/2" or so. The tires had been installed at the track, so I was braking hard on them about an hour after installation and I assumed that was the cause. I don't have enough power to rotate the rear.
As for weaving, did anyone notice how some of the F1 guys in the China GP seemed to be using lots of understeer behind the safety car to heat up the fronts.
