DE helmet. Full face or open face?
If you have airbags, consider the open face. There have been some studies about the danger of your chin getting snapped forward when the bag inflates.
Otherwise, popular opinion holds that the full faces are safer. (They're hotter, though, and your field of vision with them can be smaller.)
If you value your face, buy a full face helmet. I'm surprised open face helmets are even allowed anymore.
As for the study (just one) it was done by the FIA to evaluate using airbags in F1 cars. Somewhere along the line someone assumed this applied to all airbag equipped cars and started a sudden and misinformed (but thankfully short lived) panic.
I use the SR Pro from Bell. It's a fuff face helmet but with a larger opening which is a lot cooler. Works great with goggles if you ever need them. Great sedan helmet I think.
Another voting with Jack. I'd much rather have a full-face helmet provided there are no air bags. The SCCA last year even debated banning open face helmets in cars with air bags. It appears full-face helmets and air bags leads to an increase in broken jaws and neck injuries.
Other features you should consider are weight, outer shell size, and getting an SA helmet. Look for the lightest helmet, with the smallest shell size you can afford. A helmet that is heavy, or rubs against the seat back, will not be very comfortable. Make sure you get an SA rated helmet. A lot of clubs do not allow "M" rated motorcycle helmets.
For what its worth, I was in a head on with a concrete wall. I have a 6 pt. harness. The airbags deployed. Interestingly, they never touched me! So if you have a full harness I guess it doesn't matter.
Super Moderator
Needs More Cowbell
Needs More Cowbell
I run a full face sedan racing helmet, the OMP Turismo, similar to the Bell SR Pro discussed earlier:
http://www.motorspot.com/702204.jpg
http://www.fastraceproducts.com/omp_...elmet_0702.htm
SA2000, wide eyeport (I wear glasses) with removable sun visor. I've been very happy with it.
BTW - you probably are already aware the new Snell 2005 rated helmets are supposed to be available in Oct. It will be interesting to see when we can readily buy them; as it is about time to replace mine....
Norm
Norm
Norm
Norm
I also wear glasses so it will take a few seconds more to put on the helmet because with the open face, I never had to remove my glasses...
Full-face.
I think a cool option is the Stand 21 "Double Duty", it is a closed face helmet that has an interchangable visor (like the OMP above) and face shield, so you get the best of both worlds and can go from open cars to sedans with the same helmet, an added bonus is that it comes in silver instead of refridgerator white. Very nice and lightweight helmets with a very large price tag.
There has been no evidence considered (to my knowledge) that relates to passenger cars.
Originally Posted by Wreck Me Otter
I've had a rock enter the side window and smack my faceshield just under the eye, putting a pretty good chip/crack in it. I'm SOOO glad that wasn't my face.....
