Interior Painting
George -- The best product you could use is PPG's epoxy primer for both adhesion and corrosion protection. It is actually recommended that on modern unibody cars that this primer be applied prior to doing the body filler or "bondo" work as it sticks better to bare metal than any filler can and has factory quality corrosion protection. It comes in several colors (gray, black, white, red, blue and gray-green) and does not have to be top coated. You can use two different hardeners with it, DP401 or DP402 and I would recommend the 401 even though it requires an induction period of 20 minutes after mixing. In areas like interiors which are subject to a lot of overspray you will get better results.
It can also be clear coated if you would like a gloss finish instead of the semigloss 'out of the can'
Bruce Phillips
Professional Paint Supply
Bruce Phillips
Mark (Red),
Regretfully I don't have any close up shots currently. I should be picking up the car soon and will take them then to send to you. Please drop me a line if I forget to do it.
Cheers, Juan
Cheers, Juan
Not sure exactly what paint they used, but it was the done via the electrostatic charge method. The paint seems pretty tough with no drips anywhere to be found. Surface prep + primer + three coats, cost was about $600. Very happy with the result.
Originally Posted by Greg Fishman
Has anyone ever powdercoated the interior of their car?
I know you are looking for advice on prep and primers but I recently took out just the carpet on the driver side of my 944 and encountered tons of goey crap. I scraped it and then I purchased some industrial adhesive remover. After about 4 hours I was left with a bigger mess than I started. I cleaned up what I had with a scraper and a wire brush and ultimately went to Home Depot and bought some very thin sheet metal. It took me a couple of hours but I fabricated a floor using my floor mat as a template and went up the side of the tunnel. I then riveted the pieces in and it looks pretty good for a race car. Just a suggestion on the floor since I know exactly what you encountered.
Good luck!
Good luck!
Originally Posted by RJay
No baking, no ovens, no waiting.
