Steel sleeves
Basic Site Sponsor
Basic Site Sponsor
Originally Posted by Porsche Tech
Perhaps you just didn't read the post properly- (no flame intended), but i said cross drilled, not KNIFE EDGED.
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Larry Herman
Past Flames:
2004 GT3 Track Car
I found a stock S2 block.
Thanks,
Gregg
Thanks,
Gregg
On the idea of impregnating the bore with silicon with felt pads, I don't think it is going to happen. The 'Silicium' which is German for silicon will remove flowed aluminum from the surface. The realatively soft aluminum would partialy cover some of the free silicon in the matrix after machining. It is somewhat like a vibramet polish. The silicium polish leaves the harder free silicon particles in relief.
I have a hard time believing that one could force silicon with felt into the substrate in any quantity that would adhere in a combustion chamber. On the other hand silicon will disolve in aluminum at about 1300F even though silicon melts at a much higher temperature. That silicon is fully trapped in the eutectic phase.
Just looking at the technical side.
It is already gone !
Perhaps you just didn't read the post properly- (no flame intended), but i said cross drilled, not KNIFE EDGED. There is no weight change to the crank. It is strictly for improved oiling to the rod journals for durability issues. An additional oil hole is drilled in the rod journals along with eyebrowing the hole to allow for better oil flow out of the holes. There is NO performance benefit. The benefit lies in not throwing a rod through the engine block.
