5 pt or 6 pt belts
#46
It would be useful to know the configuration used in testing for the various devices. As Geo and others have said, it's generally wise to follow the guidance of the pros (Gideon/Melvin et al). However, I would much prefer to know specific answers to the configuration questions brought up in this thread.
For example, just because G&M strongly recommend 6+ pt, it's not convincing if installed through the single central hole; unless they have tested that configuration? Likewise, looping 6pt subs under the legs and back through to attach to the same hardpoint as the lap appears to me possibly to enhance in one area and detract in another?
#47
#48
You know if people are worried about the 5pt sub hole being used for the 6 point as an extra stress on the seat, why not just go to 7 point? Isn't 7 point like the 5 pt with the dual sub as a parachute anchored at the lap belt harnesses and either coming into the seat via the lap belt holes or dedicated holes in the few 6pt harness seats? By the way, Does this list have an opinion as to the best 6 or 7 point that causes minimum damage to your privates? I think that would be the dual sub hooking through lap belt holes, then the "T" style with parachute, then any kind coming up through the 5pt seat bottom sub hole. Which manufacturers like the first kind?
#49
Originally Posted by APKhaos
Thanks John - great posts and you've managed to keep this important thread on point.
After talking to our safety chairman, who is a professional in aviation safety during the day, and has just attended a seminar given by John Melvin & others, I'm feeling good about the 6 point Schroth thats going into my car. The Schroth is a 'wide gap' style designed to be installed in cradle configuration. Was planning to install the sub straps in a normal 'forward through the sub hole' configuration, but am now giuded by the wisdom and test evidence in support of the cradle setup.
Which Schroth harnesses are you installing?
Are they an 'F' version?
#50
Follow-up question on 6-point
OK, So I've been looking around the web for 6 point belts with the "wider" sub belt arrangement (like John's posted pic of the blue hanrness), and NOT of the simple T-bar or V sub-belt configuration. Found that Simpson's ("Platinum" harness) and Crow have the most reasonably priced camlock units with this wide sub-belt configuration (for "comfort" you know ).
Question: It is not clear to me from their pics how one straps in. From what I can tell, the sub seems to wrap through two D rings (one on the end of each terminating part of the lap's end) across both lap belt ends. So if this sub belt is a continuous piece, how do you strap in if the camlock part is fixed to one of the lapbelts (that's how my 5-point Sabelt is ...camlock is fixed to the right lap belt), and an unbroken sub passes through D rings of both the left and right halves of the lapbelt. I know there's gotta be something easy that I'm missing here. Anyone own or seen one of these types know. I'm looking to pick up such a 6-pt belt and hate to buy blind based on an internet pic alone. Thanks!
Edward
Edward
#51
I don't see why one 6-pt is theoretically better than the other. I have not ready anything to this effect other than marketing from manufacturers. It seems to me that all styles will prevent the shifting of the pelvis that leads to the chest injuries.
Anybody have anything on this. Vaughn, did Dr. Melvin have anything to say about the style of 6-pt he recommends?
#53
#54
Edward
Edward
#55
Geo, et al;
General offerings: Simpson says;
In case anyone thought that I had been flatulating in this thread, here it is in somebody else's words. In regard to 6-point systems, Simpson says;
Will any 6-point take up slack and stop body motion sooner? Yes. A "V" type sub may be nearly as effective, but it has two dissadvantages as I see it. 1st it is going to trash your gonads! 2nd, it is essentially central in the space between your thighs. The wide-terminated, non-clip-in type of 6-point (as pictured twice in my posts) will rest on either side of "the kids," will have a wider coverage area - or footprint if you will - and should therefore offer more stability, retention, and load disipation, and will be much easier to secure snuggly and more comfortably to the inside of the thighs in a static state, decreasing the amount of time that it takes for full tensioning of the system to occur.
The choice between getting bruises to my groin and inner thighs or having my onions diced is not one that requires a lot of thought on my part!
6-Point Anti-Submarine Belt should be anchored at an angle of 20 degrees behind the Chest Line as measured from the intersection of the Chest Line and the lap belt buckle. Mounts should be approximately 8 to 12 inches apart (approximately located under each hip and as close to the body as possible). Two routing holes in the seat or a special seat mount may be required. Using the 5-Point hole detracts from the effectiveness of this system.
“We have found that the Platinum Series belts, especially in a six-point system, fit more snugly and hook up on the pelvis and hips to more efficiently control body motion,” said Doug Doolen, Simpson Vice President of Sales and Marketing. “The Platinum Series belts catch the body earlier in the crash equation, minimizing momentum buildup and allowing more time to ride the energy down, reducing the whipping effect.”
#56
Geo - looks like Mark was taking better notes than I was in this respect (or the coverage has gotten better). IIRC the first time I heard the talk (from Melvin) I think Willans was the only company (at least that I was aware of) making the wide 6-pt setup. I'm glad to see there are more choices now. All this discussion has me thinking maybe next time my belts are up I'll pony up for some new more comfortable belts. Never had a comfort issue with my traditional 6-point mil-spec latch RJS belts, but maybe it is time to upgrade the belts to the same level as my other gear...
#57
#58
Originally Posted by SundayDriver
Some belt/car combos give rise to a new meaning for 'Cup Car'.
Thanks for the info Mark.
John, I had previously read the stuff on the Simpon site (or in an ad, I can't remember), but I'm not terribly swayed by ads and marketing. If I were, I would think all H&N restraints were better than all the rest.
I kept reading about Dr. Melvin being very high on the 6 pt harnesses, but I had never read anything about one style vs. another. Absolutely my mistake for assuming any 6 pt would do the job properly. I wish the experts would be more specific when there are choices to be made. I'd be PISSED to have bought a 6 pt only to find I bought the wrong style 6 pt.
It's wonderful that there is so much safety testing and R&D going on these days. But the problem is, the information is absolutely NOT being disseminated well and the rest of us fill in the blanks the best we can. I try hard not to do that but I did this time through omission. Just goes to show that's just as dangerous. For sure I'll be ordering the DVD and I hope it will not only be enlightening, but provide more specific answers than have been generally available.
Anybody know what is available from SAE and if it's worthwhile to order (print or other media)?
#59
Mark,
Thanks for the reply! But if I understand your description correctly, you "thread" the sub belt through the D-rings... Wait a minute...Aren't the ends of the sub belt already bolted to the car? Gotta be something easy I'm missing here. Forgive me if I just don't "get it" (I'll probably just have to go see one for myself). But if only for my own pesky curiosity, I'd like to know how one straps into this type of belt before I go order one.
If anyone can clarify, that'd help. Great thread, BTW. I know I'm picking up a lot.
Edward
Edward
#60
Edward -
If my guess is right (and that's all it is), the end of the sub has a loop sewn in it. This end is threaded through the metal positioning loop on the lap belt, and then the end-tab for each shoulder strap picks up the loop on the end of its sub strap. That's my guess for the Rotary type. I just can't figure how the Latch & Link style Simpson works at all.
Suffice to say that it likely makes getting strapped in much more of an ordeal, as Mark eludes to. Safety often comes at a price.
