Building a race car garage?
Don't forget to add internet access of some sort. I suggest wireless as it is the most flexible.
You should also give lots of consideration to drainage. You might want to contact a garage expert (ie Ultimate Garage) and express your needs. It never hurts to ask a pro, although it sounds like some of the guys around here have more than enough experience.
I have noticed that your decisions will probably be driven by how much fluff vs. function you want. Some go for the nice tile, fancy lighting, etc. Others basically build a small pro shop. I would lean towards Helmut's suggestions because I think the cuteness of fancy materials would wear off quickly.
Also, in my opinion, some of the neatest setups have a loft for storage/office space. You might look into building an external set of stairs and a dumbwaiter-style hoist (probably for parts and tires) to a loft space above the garage. Although if you have an abundance of land it might not be worth it.
Good luck and keep us all posted on your progress.
Max
Max
