UPSIDE DOWN GEARBOX, HUH?
RL Technical Advisor
Johan:
Turning the gearbox upside down gives you much better drive shaft angularity and CV joint range with a car that is VERY VERY low.
One fabricates mounts, a tranny oil pump & cooling system, and some shift linkage changes.
The back seat sheet metal is all removed of course and replaced with custom sheet aluminum secured by dzus fasteners.
1 Post
Steve,
There seems to be quite a few advantages to flipping the box. Does it not help with reducing the centre of gravity because the engine is now placed much lower to the ground or does the engine remain in its present position. What happens to gearshifting? Is first gear now on the opposite side as to where it was with the box right side up?
Originally Posted by Steve Weiner-Rennsport Systems
The 930 Ring gear gets swapped to the other side of the pinion inside the bellhousing,.......![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
1 Post
Don' you just love innovative ideas! When I look at drawings of a 915 box it seems as if the engine could be lowered as much as 8 inches. Is this not a major (beneficial) lowering of weight for a track car?
The hypoid offset of the G50 R&P doesn't allow for a simple ring gear flip. It has been done (for mid-engine kit car use), but at incredible expense. There is a new mid-engine 6-spd sequential transmission presently being designed around the G50 Turbo R&P, but it will be quite expensive.
