Racing Pedals
Hey;
I cannot overstate what Tony and I are getting at here. Unless you have tried a solid pedal like I fabricate, or like Tony says the AJ-USA pedal is, you will not have the frame of reference to know any different. When you DO try one, it will become quite apparent that your tack-ons are junk!
Mike -
You will note that the pic also shows a widened and spaced brake pedal extension as well.
I can make you a set. I will PM you.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have been working on sharpening up a new 944T race car for a client, doing all sorts of odds & ends to shore things up and make it more enjoyable and effective. I asked him the other day what he thought the best improvement was (out of many so far) - after a few events in the car now - and he said by far it was the Heel & Toe pedals!
Mike -
Ok, for your cheapskates out there... I use factory pads on the clutch and brake and tape a block of wood to the throttle pedal... laugh if you must, but this allows me to shape it exactly the way I want it... a quarter inch too wide? fire up the old table saw... 1/8 inch to low".... wood glue and shims. .. cheap and easy... about ten cents and no waiting..
Plus.... real race cars have duct tape on them.....
