Optimoly HT - what is it?
Per the bentley manual prior to attcahing the transmission to the engine the spline should be lubricated with Optimoly HT or equivalent.
What is this , where do you get it ? and what are the equivalents?
Earl
Earl
I think it's High Temp engine assembly grease and I think you can get it at a good Porsche delear parts department. When I replaced the clutch on my 944 last year I used some cheap engine assembly grease from the local auto parts store. Nothing has locked up or fallen off since then.
Mark
Mark
If it's on splines, it's likely something similar to a white lithium grease, something that can take shear loads and keep the splines from rusting or sticking over time.
Sam
Sam
I don't remember if if was HT, but I'm familiar with that lube. When I got my 993, I had a problem with the clutch disc hanging up on the spline, and not easily releasing from the flywheel. That is what the optimoly is for--to lube the shaft and last atleast the life of the clutch. Otherwise you'll get corrosion and hanging up. Optimol is what's specified by the factory, and I had a heck of a time getting it. Turns out most dealerships can order it. A lot of shops said they used wurth antisieze compound instead.
