Flat shift and fishtailing in the GT3
Basic Site Sponsor
Basic Site Sponsor
Received 3,307 Likes
The next gear to be selected is already pre-engaged using one of the two dual-clutches, all electronically controlled by a GCU.
The entire operation, when you are asking the maximum like the OP was, takes between 50-60 milliseconds. Barely perceptible.
Jeez, I remember in the early days where these things took three to four times as long to do that...
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Basic Site Sponsor
Basic Site Sponsor
Rennlist Hoonigan
which cost no drachmas
The double clutch input shaft is super trick. The crazy part is it goes back to the 956!
To the OP - hit up an autocross, DE, Porsche Experience, or similar to build some skills if you are going to drive that spirited. You have a very high performance car.
Basic Site Sponsor
Basic Site Sponsor
With the combination of the lighter flywheel and the lighter clutch pedal pressure (in the 992 GT3 Touring), they do hype it as possible to no-lift shift it. There are some electronic high jinks at work to smooth it out and prevent overrev if you miss it, but that’s what I’ve heard.
Basic Site Sponsor
Basic Site Sponsor
From an owner:
Just as the automatic rev matching makes for a smoother downshift than a human can achieve, the no-lift shift does the same for upshifts (computer perfectly matches the revs to the next gear). It’s particularly smooth at less than full throttle.
The nice thing about the Manual is you can do it all yourself or let the computer do it - very flexible
Basic Site Sponsor
Basic Site Sponsor
The ECM and GCU in the six-speed evidently match revs up and down. Going up allows part-throttle and full throttle flat shifts, but there are other reports that the full throttle flat shifts in the lowest gears can get exciting! Very sophisticated electronics is how they do it, with a combination of varying engine load using fuel and ignition cut so fast you don’t even notice. Spectacular.
based_1 (01-08-2024)
Are we talking about the No Lift Shift? That is a feature in the last 2 or 3 generations of manual transmission GT3s. You still have to clutch, you just don't have to lift the throttle.
Otherwise we'd have to be talking about a PDK.
The following 2 users liked this post by Nickshu:
GT3_Driver (01-08-2024),
ProCoach (01-08-2024)
You might want to look in the 992 GT3 sub forum, I think there has been some discussion on the no-lift feature.
Another thought is that you said you were in Sport mode and I believe Sport allows a bit more tire spin and slip before ESC/TC acts. If you can safely try it in normal mode the car may act differently
Enjoy the car!
Enjoy the car!
based_1 (01-09-2024)
Basic Site Sponsor
Basic Site Sponsor
As pointed out, the latest versions of the GT3 manual (after the reintroduction, I guess) have some very sophisticated electronics to make this possible both in part and under full throttle.
Basic Site Sponsor
Basic Site Sponsor
Here's the best video I've seen about it.
Basic Site Sponsor
Basic Site Sponsor
Have to use the clutch, just don't have to lift off. Start at 8:00 for the explanation. Start the video around 8:54 for the demo.
