Is base 987.2 2.9's PDK cooling enough for a track?
#31
Coolant level can be checked in the hatch area next to where you fill the oil. Open the coolant cap (when the car is cold!) and you can look down the tube and check the level.
I suspect the thermostat if you have enough coolant. Not 100% on the Porsche, but in general, radiator fans wont turn on when the car is running as there is airflow going through the radiators already. They turn on when the car is stopped so it can pull air through the radiator when you are stopped.
If the thermostat isn't opening, than the radiator function isn't even being used to cool down the coolant.
Opposer (07-11-2023)
#32
I meant the Cayman plaform in general, but I still see them. not everyone who wants to go to the track has an S.
Here's what a mildly modified 6-speed 2.9 (IMSA ST) can do around COTA in the wet. https://youtu.be/sTC9UXOeVWc
#34
It's the old "Street Tuner" class that has been replaced by the TCR class about 4-5 years ago.
A Win’s a Win for Continental Tire Challenge Street Tuner Team Bodymotion Racing | IMSA
