Aluminum Nitrogen bottles
Bought my aluminum cylinder at Prestacycle.com, an online bike supply shop. I use a transfill hookup hose and gage to fill the aluminum cylinder from steel N2 cylinders that I have in my garage.
Another Option Chris Styles
Purity Gas Inc.
14-760 Pacific Road
Oakville, ON L6L 6M5
P: (905) 335-6040 | C: (905) 520-8147
E: cstyles@puritygas.ca
www.puritygas.ca
Purity Gas Inc.
14-760 Pacific Road
www.puritygas.ca
Standard aluminum cylinders are good for 2000 to 2200 psig in Canada & USA. Our largest aluminum cylinder holds 265 ft^3, compared to the same size steel cylinder which has a higher pressure rating (up to 4500 psig), which allows it to hold 493 ft^3 in the same physical space. Tradeoff is that the steel bastard weighs 150lbs, the aluminum just 80lbs.
Anyone local in the greater toronto area is welcome to pickup (and refill) cylinders from us at our shop in Oakville, and we also have a cylinder filling station installed inside Braidan Motorsports trackside @ Mosport.
Edit: if you guys have sources for filling your cylinders, our manufacturer is in the USA and we can drop ship these straight to you (empty) from within USA to avoid customs hassles / expenses. Just drop me a note if interested.
I went direct - https://www.catalinacylinders.com/
