Wright Device Head and Neck Restraint
<edit> Smokey, my post was not intended to challenge your words, even though it came right after yours.
Neck collars do absolutely nothing for basil skull fracture. Your neck stretches with basil skull fracture and your helmet won't even be touching the neck collar when your neck breaks.
I've first hand experience with a neck collar and how it works to save your life. One saved mine. I had someone hit me so hard from behind in a kart than the entire kart and driver ended up on my head (325 lbs total). The neck collar prevented my neck from breaking (especially due to the angle of impact - right where a hangman puts the knot to break the neck). But, it was a compression impact, not tension as with a basil skull fracture.
As for all the H&N devices our there, IMHO the only two to consider are the Isaac and the HANS. Personally I have two misgivings about the Isaac.
1) The requirement to pull release pins to exit the car.
2) The angle between where it attaches to your shoulder harness and were it attaches to the helmet.
The thing I really like about the HANS is that the restraint works on a horizontal plane. I have great misgivings about devices that work at an angle. I rejected the G-Force restraint that my helmet is set up for due to this exact reason.
But again, I consider the Isaac the only reasonable alternative to the HANS.
All of the restraints that attach to your body via straps have a built-in flaw: they can move around as can your body in an accident. The HANS and Isaac at least are attached to the restraint that keeps your body under control and they won't slide around.
IMHO anything else is a waste of money. My future includes a HANS. Perhaps as soon as this summer. All I need now is a new job (I'm leaving my old one at the end of the month and the only reason I'm not ordering a HANS now).
I am a super advocate of safety. If you don't mind a disposable device then start with the Wright device and if you continue to do DE's as I'm sure you will, then get a HANS (my recommendation) or Isaacs. The HANS is the most popular and is used by the pros and all the EMT personel know how to disconnect them in a hurry.
Just my .02
One of the things I was thinking about doing on my helmet this year was putting a decal on each side above the Isaac release pins that says "release" just to aleviate any confusion. On the other hand, I went to a seminar last year for F&S guys (think it was a form of accreditation for them), I am pretty sure they cut the belts when they have to take you out so in that case it would be of little concern.
Two things I'd note on strapping systems. A.) I believe they (straps) must be replaced on the same interval as your belts so there is an on-going expense (but check the rules you race under, this might be of no concern) and B.) you can definately be less or more protected based on how tight you pull the straps. This is of-course true for any strap, be it your harnesses or your window net or your Hutchens or HANS, etc ... the thing I have liked about the Isaac from the get-go was that the only way I could attach it incorrectly was to not attach it.
Computer simulations have shown the Isaac to work on lateral impacts, I do not know how well the other systems measure up in the same simulation. I know first hand however that after a massive side impact, I sure as hell was glad to be wearing my Isaac.
I apologize if I sound too slanted to the device I wear but after a very bad meeting with a concrete wall, my confidence and satisfaction with the Isaac device went through the roof (enough to call the product designer two days afterwards to thank him - wanted to wait long enough to make sure there wasn't a surprise neck pain or something).
Bottom line however (and I think all the manufacturers would tell you this) is that they all work to some degree or another. Some just work less well. But any system, fastened and adjusted properly will significantly lessen the load during an impact.
It is really termed a Basal Skull Dislocation, since tendons are the only thing that holds the skull to the spine. Fracture is a misnomer that I too was guilty of uttering.
Don't discount the neck collar. My Neurosurgeon Racer friend says wear one by all means. They are not an H&N system, but they are nonetheless helpful at lower speeds. He wears a HANS.
The Isaac is the only system that virtually eliminates ALL head acceleration.
The Wright does seem to only work longitudinally. Too bad if this is true, as offset is FAR more dangerous.
No one should feel silly wearing safety gear anymore. Not with what we all now know.
There is an H&N system in my future, along with the head retention panels I am designing for my seat right now.
From the CDC website:
http://www.cdc.gov/ncipc/pub-res/bibg1995.htm
McElhaney JH, Hopper RH, Nightingale RW, Myers BS. Mechanisms of basil skull fracture . Journal of Neurotrauma 1995;12(Number 4):669-678.
If it's good enough for the CDC it's good enough for me.
Could anybody summarize the SAE article? Google can't find it for me and I don't have the time to search.
Thanks,
Max
http://www.sae.org/servlets/productD...D=2002-01-3304
Twelve bucks to download...
I can tell you this, after the safety thread I went all out for safety. I replaced my seat and fitted my helmet with HANS and now recommend all track drivers do the same. You don't look stupid in DE with all of these things.
The neck roll no matter how it is devised, will do little if nothing to protect you. They offer no support in extension and very little in compression. If you can easily deform it with your fingers imagine what it will do under the g-force generated in a crash.
B
Saying it took extra time to removed the Isaac pins, assuming that you get the upgraded one w/ the push button release, I can't see a child even taking that long! Push the button, maybe wiggle, and pull the pin out. 15 seconds at most. Now I agree, not all corner workers /EMT's have seen them, I've taken to make it a point that word is passed on that an Isaac is at the track
Bill
Cheers, James
