Brake pads: PFC 08 vs RSL29 vs RE-10
Hi folks, I have a 2010 911 Turbo with stock 350mm iron rotors. I’m beginning to look at brake pads for the upcoming DE season.
I’ve searched here to try to get some feedback from the pros on which pad would work better for the heavy Turbo.
I normally run group 2 and my tracks of choice are Road America, Gingerman, and Autobahn Joliet.
Pagids RSL29, PFC 08, or race technologies RE-10 (although I don’t think they make it in the turbo size, and if so, down to pagids or Pfc).
Can folks that have used the pagids and pfc comment on difference between them
and longevity? Searching here revealed that apparently the PFCs last a bit longer as they are effective to the backing plate, whereas some have commented on the pagids not being consistent past 50% wear.
All comments and suggestions welcomed. Thanks
Received 1,809 Likes
10 pages, over/under?
Can you get Ferodos in that size? Love my Ferodos. Still running the DS1.11's and still loving them. 14 981S
Looking for recommendations on pads for my (new to me) GT3 as well. Still have the stock pads on.
20 pages? Over?
20 pages? Over?
Haha, I’ll go with under 20 pages
P. I have a 2010 boxster S that I have tracked for 10 years and because it’s so light (under 3000 lbs) the textars sport pads worked well enough to do my usual 3 DEs a season w/o brake fade. And cheap, so I would just replace them each year.
With the Turbo, tracking only last year, stock pads are gone after a weekend. So now the need to pic the expert’s brains on better pads.
I think ferodo makes the 1.1, in my size, but not the newer 3.12. I’ve also heard folks that truly race their cars that the PFC and Pagids were better than ferrodo. I’ll let the experts chime in
dgrobs (02-16-2020)
I think ferodo makes the 1.1, in my size, but not the newer 3.12. I’ve also heard folks that truly race their cars that the PFC and Pagids were better than ferrodo. I’ll let the experts chime in![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
At the end of the day any of the sprint or endurance race pads will give you a better performance than OEM pads, you just have to consider the trade offs of wear and cost, your personal preference and car setup, which usually means picking between a more instant braking torque or a more flat curve, with trade offs around modulation and possible fade.
Again, no right or wrong answer, and certainly no universally perfect pad out there, so maybe trying each one over time is the way to go
No ideas what pad costs for your particular car but my experience with PFC products has been amazing. Run to the backing plate and zero fade and no bed in process. Have also run DTC 60 and DTC 70 pads with success due to my budget constraints.
I am not an expert and really cant think of a time when brakes effected my enjoyment on track except when 1) pad deposit issues and 2) brake fade from non race pads
Cant go wrong as long as it's a tried and tested pad that is recommended by the knowledgable folks on here. If you have the budget, I would call Clark at Apex and go with whatever he and Linda (I think that's their names but have a horrible memory) recommend. They have GREAT prices and also may give you a discount if you mention rennlist. More importantly they are great people to work with in my experience.
Basic Sponsor
All comments and suggestions welcomed. Thanks![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
Clark
ApexPerformance.net
Premier Racing Outfitters
Toll free: 866-505-2739
Direct: 843-299-0997
EM: chamerly@apexperformance.net
www.apexperformance.net
Save 10% on your next order over $75 on most items- enter Promocode Rennlist-10 on your next order or mention Rennlist during your phone order.
PCA Club Racing - National Sponsor
Clark
ApexPerformance.net
In as much as I sell PFC 08, RS29, RE-10 I will throw in my 2 cents. Most of what I am telling you here I have learned from customers using the pads. PFC 08 lasts substantially longer than RS29 . RS29 starts to fade at 1/2 a pad. RE-10 Has good modulation and the pad will last but it has very poor initial bite and costs $$$$$ big bucks. Ferodo DS3.12 is the new favorite. IT has more initial bite than any of the others and the modulation is to die for. You are correct about no DS3.12 in the pad shapes for the 997 Turbo (FRP3075 and FRP3143) But this is available in DS1.11. I will get the DS3.12 made in the pad shape for your car. Hang in there.
edit: I just emailed you. Thx
Don’t forget the new endurance compound from Pagid that supersedes the RSL29. The RSL1. It’s a step up in performance on most dimensions.
350mm iron rotors. At least I can’t find it anywhere in that size.
That I don’t know. They aren’t carried many places unfortunately, but give Paragon Racing a call. Jason knows what is available and compatible.
PFC 08s are my current favorite. I tried the Ferodo DS111 but did not like them b/c I felt they lacked bite on initial application. First I have heard of the Ferodo DS312s mentioned by Clark above. I used to run Pagid yellows (RS29s) before that.
Downside of the PFC 08s is they are hard on the rotors. Trade offs I guess.
As suggested above this is a highly personal choice, yo have to try and see what works for you.
My two cents: pfc’s are really easy to live with on track. No problem bedding them; consistent all the way to the backers, somewhat reasonably priced compared to pagids, and they stop great.
On the street, they have an unmistakeable “pfc squeal”.
Thanks to everyone for the feedback. I’ll give the PFC 08s a try; I’ll report back in May after my first DE of the season at Road America.
I particularly like that they are “easy” and dont need bed in and appear to have nice initial bite, while also lasting long. I don’t mind that they squeal like pigs for the street for the 5ish warm months I’ll have them on in Chicago. I’ll change to stock pads once the winter wheels/tires go on late October.
thanks![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
thanks
thanks
May upgrade rotors later on so rotor wear isnt a huge deal
