Spec Cayman suspension question
For those of you who have Spec Caymans, I'm curious what you are running for sway bars and how you have the bars adjusted (which holes you are using). The rules allow several different bar options, although the JRZ Spec Cayman coilovers are mandatory. I'm setting up a dedicated Cayman DE car, although it is not a Spec Cayman racer and I already have the Spec Cayman JRZ's. I'm looking for a starting point on sway bar setup before I go back on the track in a couple months.
It depends... You really need to tune them to the rest of the setup as well as your personal preference.
I would suggesting running a few laps at the extreme settings (front full stiff and rear full soft) then swap (front soft, rear stiff). See what your butt dyno says, then you can start honing in...
Otherwise just run them centered both ends.
I've got a front TPC bar for sale for $300 now. It has 5 adjustment settings. Cheap way to see if you prefer a stiffer set up than stock. We went to a cockpit adjustable bar on our non-spec Cayman.
https://rennlist.com/forums/parts-ma...sway-bars.html
Do not run them full soft front and full stiff rear unless you want to do repeated mid-corner spins (assuming you will drive near the limit of the tire).
Would strongly recommend, per jscott82's initial suggestion, that you run full stiff front and full soft rear... and then adjust one end, one hole at a time to tune for preference, track, and the balance of your setup (rake, alignment, tire pressures).
Per the SPC rules you can run Tarett, TPC, or Gt3 sways (including mixing and matching to find the best front:rear balance spring rates).
WRONGLY ACCUSED!
Received 3,461 Likes
Also depends on the conditions. If you are going to race in the rain you may want to soften them up.
As others suggest, the best way to do it is to play with the settings on the bars and figure out what you like. My previous car was the test bed for the SPC JRZ suspension so I got to play with it a little before it was cast in stone.
WRONGLY ACCUSED!
We run a special turf setup for NJMP. Best to disconnect the sway bars for more suspension independence. Helps to maintain tire contact as you transition from turtles to the, uh, non-paved surface.
