sim: static vs motion for driver training
#31
Word.
Good to see Elliott Skeer here! Not only is Elliott a fine driver, but also a trailblazer in effective remote sim coaching.
Why practice the wrong things when you can have Elliott help you practice the right way around a particular circuit?
Also, go through a set up sweep in a session and SEE/FEEL the difference in the way the car behaves, and talk through these changes with Elliott or another experienced remote sim coach. Hit the track at speed, instead of spending all weekend getting there.
All kinds of good things can happen using resources readily available...
Exactly the point, NBA players can just go shoot a thousand shots a day, cant run a thousand laps a day without a Scott Tucker budget!
The beauty of the sim is being able to get as close to a real race mental mindset as possible, I've had heart rates on the sim be higher than the real car at times, helps create the pre-race nerves commonplace
#32
I've also seen some software you can buy (can't recall the name off the top of my head) that, combined with adding a separate sound card in the PC dedicated to shaker control, intelligently and independently drives 4 shakers (left front, right front, left rear, right rear) in iRacing. I'm not planning to do that yet, but might if the stereo effect isn't what I hope.
#33
So I ended up selling my seat mover NLR V3. It was fun in VR but the problem is getting thrown around in the seat and trying to be consistent in driving. I'm sure everyone has a different level of what they consider to be immersion. I enjoyed it while I had it but I'm quite happy to have moved on. Also, the feedback from the direct drive wheel is more granular, now that I'm no longer using the wheel to hold myself in place. There's also a notable improvement with the consistency on the pedals as my distance to the pedals is not being altered by the seat moving around.
For an easy DIY setup, get a 8020 simlabs rig with a direct drive wheel and high end pedals. Add VR/tripple screen and you're set for a long time.
#34
Location: On a pygmy pony over by the dental floss bush
What are your thoughts on the best way to wire the seat shakers? I'm in the process of replacing a single Buttkicker with 4 smaller puck shakers. I plan to drive the 4 shakers in stereo (rather than LFE/mono with the Buttkicker) so that the left channel drives the 2 shakers on the left and the right channel drives the shakers on the right. I'm hoping this will result in more realism with the left side acting independently from the right (over curbs for example). I haven't tried this stereo approach on iRacing yet, so I really don't know how well it will work. I'm just going to wire it up (when I can find time) and see what happens.
#35
#36
Absolutely this is the way to go. Full motion is much more of an ineffective party trick when trying to make the sim driving as consistent as possible. 8020 is a fantastic way to build a rig, the one thing I would say is to start looking at curved monitors vs triples. They are really starting to drop in price and IMO are more effective than Trips because of the single screen without bezels cutting right though the view.
#37
#38
#39
I will check it out if stereo doesn't get the job done.
#40
I had a single Buttkicker Gamer 2 before and I really disliked it -- way too large, and it would rattle with the way it mounted clamping on a post, the power button on the wired remote almost never worked. Adding another Buttkicker would have provided left/right cues, but I did not like the Buttkicker I had at all. The tiny Daytons are not individually as powerful (though shockingly powerful for their size), but 4 of them, well placed, works really well for cues. If you want to bend the 80/20 frame with vibration you probably need something stronger, but if you want cues, the pucks are really good despite their tiny size.
#42
It took many months, but I finally had time to hook up the shakers with a stereo signal and it works great. A million times better than mono because it definitely gives you left/right cues, but it obviously doesn't give you as much granular control as sim vibe software does. I used 4 small Dayton pucks (https://www.parts-express.com/dayton...8-ohm--300-386) mounted under the the 4 seat supports and they are plenty strong enough for cues. I wired 2 on the left and 2 on the right in parallel to create a 4ohm load on each side and am driving them with a small stereo T-amp. The key is to get the crossover setting exactly right and low enough so that sounds don't bleed through and create false shaking (for stuff that shouldn't shake).
#43
I used a short length of "1x5" wood (3/4" x 4 1/2" actual) and a 70mm hole saw (
) to mount the Dayton pucks on small blocks of wood, then bolted that wood on the 80/20 frame using 5/16" x 1.25" bolts with slider 5/16" nuts in the frame.
#44
I agree with most of these posts.. really good static rig is the way. Many options depending on budget and how much realism you are willing to pay for.
Strongly recommend a 80/20 style rig as you can infinitely adjust in the future. Several good manufacturers from the cheaper 4play rig to the HE setup and beyond.
HE Pro pedals (now replaced by the "Sprint") are amazing for the price point of 750 (then several great options at around $1200) and direct drive wheel is a must for realism (1000-1500) Sim-vibe+butt kickers for road feel/revs etc is really good (though setup getting more complicated now with a second sound card, amp, etc).
Triple screen or VR. If you go triples.. do your research on the monitor.
Ballpark numbers: (10k will build a very good static rig, don’t even think full motion at that number). Of course can go cheaper in lots of ways - back to the first point of how much realism are you willing to pay for.
Rig 1000
Wheel 2000
Pedals 1000
Triple screen 2000
Shakers/amp 500
PC 2500 (1000 on the GPU with 144mhz 27” triples)
Other peripherals/stuff/software 1000
hope this helps, pic of my build attached
Matty
Rig 1000
Wheel 2000
Pedals 1000
Triple screen 2000
Shakers/amp 500
Matty
