What Should I Know Re: Tracking 09 Cayman PDK
Location: On a pygmy pony over by the dental floss bush
Received 1,453 Likes
As long has Porsche dealerships have service departments, the answer to that question is "Never".
Sales is only one of the dealership owners pocket. Service is the other.
Can't see them sewing that 2nd pocket shut anytime soon....
Originally Posted by okie981
Seems pretty ridiculous to have to give your whole transmission away as an exchange for $8k+ just because of a failed solenoid or control circuit. When oh when will Porsche support repairs by qualified shops....
the following shops will Service a 6spd:
Bill Rader Motorspoets
Cslifotnia Motorsports
Autometrics
BGB Motorsports
Body Motion
Deman
Hergesheimer
i am sure there are many more. They are Audi Parts. Porsche won’t sell them but they come from a FWD Euro market A6. Only thing you can’t get is a mainshaft or a ring and pinion. But rebuilding is no problem.
Autometrics
BGB Motorsports
Body Motion
Deman
Hergesheimer
I drove mine several weekends with no reverse, just had good paddock buddies that needed a leg work out....and puuuuuush.
I was given a heads up about this thread and asked to comment by one of our dealers because it contains inaccurate information about what my company offers in the way of products. There are two PDK gearboxes, and as a result of that there are two different size LSDs available out there. When Porsche released the PDK, they didn't believe that they would ever need a mechanical LSD in the cars, and didn't make allowances for it. I will call this the "small" gearbox. Then a couple of years later, they changed their minds and created PTV, which includes a mechanical LSD as part of that package. I believe that is included on cars with Sport Chrono. It required Porsche/ZF make a new casting and a larger gearbox to fit the LSD in there. I will call that the "large" gearbox. This is the same gearbox that they use on the GT4 Clubsport racecars.
PTV did not exist prior to the 981.
Sport Chrono does not include Option 220 aka PTV (981) or LSD (987.2). This is the case on my MY 2010 987.2 CS PDK with Sport Chrono but no factory LSD. (I also have a MY 2015 981 GTS Manual (Sport Chrono included in GTS Package) but PTV was separate).
PDK was introduced in the 2009 model year (987.2). At the time of introduction, it was possible to order a pdk trans with an optional lsd in it. It was Option code 220. Does an early PDK WITH factory LSD constitute a "large" gearbox according to your nomenclature?
If so, what is the difference, other than the larger cavity to accommodate the lsd? What about the "large" gearbox makes it motorsports grade vs "small"?
Also, as you have said, the majority of the failures appear to be electronics related. Do the 2 gearboxes (again I am referring to 987.2) have differing electronic components?
Having said that, any 981 GTS will have the PTV option included for "no charge" (part of the GTS package). You would have to do a "PTV delete" to not have it on a 981 GTS. Sort of like how some GTS cars have "Alcantara delete" when a buyer wanted to have the ventilated seat option to be added. Otherwise the 981 GTS will have Alcantara seat inserts and no ventilated seats.
Regarding PTV, you are correct on 981 cars, Sport Chrono option by itself does not also include PTV.
Also, when I was searching for this car (for a year), most GTS examples I came across did not have PTV. I don't think most people would choose to delete this if it was no charge.
PTV was an option on my 2014 981S track car. I took it as it is a performance option/upgrade, as this car is only tracked. No street use.
Def an option on the 981S in 2014 at the very least.
Some questions/comments about this as they relate to 987;
To the gearboxes themselves, Porsche decided it was motorsports grade when they put it into the GT4 Clubsports. I also know very little about the electronics. Why one fails and the other doesn't is a bit of a mystery. It's part of why I made the decision I did about the baby diff. In the absence of any real hard data based explanation, I want nothing to do with it. It could have been $100k in annual sales and I likely would have made the same choice.
LSDs stress the system. On average they add 20 degrees F to the temps of the gearbox oil. Why can one handle that and the other one doesn't? No idea. And then you get outliers. BGB has one racecar with a baby PDK and it's been pretty damn reliable. Why just that one car and then we see street driven cars take a crap going to the grocery is beyond me.
I've added a rear diff (Guards LSD) which seems to have tamed it a bit, and programmed the ABS to the CCB setting. But it's still intermittently happening. The only components I haven't swapped in yet are the monoball control arm links and the solid thrust arm bushing. Could these be the culprit(s)?
I'd rather understand the phenomena rather than just continue to throw component swaps/$$ at the problem.
TIA
I've been tracking/racing my 987 SPC for the past 3 years and I am still fighting this phenomenon. I do the majority of wrenching and alignment on my car, and I'm struggling to understand why I'm getting the occasional "wicked rear sway" (nice way of describing it) on threshold braking. It's very unsettling car behaviour, especially under wheel-to-wheel racing conditions.
TIA
TIA
Op, Sadly, PDKs struggle with heat and 3rd radiator doesnt seem to help, that’s a pretty well documented issue if you google around. Good cooling is a must. There were 3 blown engines on 987.2 in club racing that I have heard of this year - all pdks. Maybe a coincidence, but those motors supposed to be good conpared to m97 junk. And of course pdks are impossible to repair and expensive to replace (new or used)...it was expensive 2 years ago, maybe more used units available today.
