PDK reliability on the track
#91
My Cayman R occasionally goes into limp mode during DE events, and I'm guessing this is heat related. I have an Aim Solo 2 DL that will be wired into the CAN/ECU. Checking page 6 of the Solo 2 DL owner's manual (link below), I don't see transmission oil temp as information that I can read/download from the CAN/ECU. Please let me know if PDK temp is something that I can monitor/download.
Also, I'm considering installing either the LN Engineering or BGB PDK cooler. Which one should I install?
Thanks!
link to Solo 2 DL owner's manual
https://www.aim-sportline.com/downlo...ns_107_eng.pdf
link to BGB cooler:
https://www.teambgb.com/BGB-Motorspo...-p/bgb_tck.htm
link to LN Engineering cooler:
https://lnengineering.com/987-981-pd...ide-mount.html
Thanks!
link to BGB cooler:
#92
BGP is "gear side" and uses an external pump, which screams "more stuff to fail" to me (sorry BGP folks). The LN cooler is normally used for hydraulic side cooling (which corrals the heat from the gear side and is also heated by the clutch action, so it gets pretty hot in there), and their kit is pretty awesome. If you already have a gear side cooler, which means the plumbing already works, you can use the same LN cooler on the gear side too. Just call them and they'll work with you. I have the LN deep sump oil pan and their deep sump PDK pan om my 3.6L 911 and it's a big help with the increased heat sink. PDK pan makes changing hydraulic side gear oil cheaper as you only need to replace the filter and gasket, so you can do it more often, as long as you make sure it is done exactly to Porsche fill spec while using strict PIWIS procedures! Working on adapting the LN XXL HX/cooler for the hydraulic side of my PDK this spring. We'll see if we can get it working before summer. Trying to make the motor and PDK run as cool as possible. Then, just drive her well on the track and think happy thoughts!
What about Gear Side cooling for LSD upgraded PDK boxes. Lots of heat created with the LSD.... wouldn't the BGB one be better in that case?
#93
#94
Has Porsche added additional PDK cooling to the 718 GT4 (982), or is it basically the same setup as on the 987 and 981 models? Curious if the 718 GT4 track folks are having the same PDK limp mode issues as those of us with earlier models.
#95
I have looked into the BGP rig. My only reservation is the external pump -- which also has to be switched on/off too -- so just more potential failure points. On my 997.2 doing gear side can't work unless I go to headers to make room. Not sure how to plumb the BGP rig either. I think BGP would certainly work for hydraulic side, and probably work well, but the LN is just a 3XL size version of the factory hydraulic-side heat exchanger, so bolt it on and good to go if you are in a Cayman or Boxster. The LN kit is for Cayman and Boxster; NOT for a 911. But, on my 997.2 3.6L there looks to be a space to place it, so I am working with my shop to see if we can fabricate a good mounting bracket that will fit and be as bulletproof as practical. I'll post here with a link to the Rennlist post when completed, if successful. While were in there, going to think about how to adapt the old HX to the gear side, but not hopeful that is going to work. We'll see. Currently hoping deep oil, deep PDK and cooler water with center rad add on will help keep the whole system cooler. Fingers crossed.
#96
#97
Very happy of how the install went on the PDK cooler and Pan, I am fortunate only being a little over a hour from LN Engineering, I actually observed the installation by Andy Rivard great guy.
#98
Very cool. I'd love to know if you see any noticeable difference in the water temps with the larger HX unit. Up a little because of the 3XL HX transferring more heat? the same? Or, down a little because it's running cooler overall? I think any scenario is a good one, just wondering which one plays out. Good luck!
