Toe conversion mm to degrees
I need to convert mm of toe to degrees. Can anyone tell me if my calculations are correct/
Front 26.8 Tire diameter (inches) Tire Rack
680.72 25.4 multiply to convert to mm
3.1416 Pi multiply to calculate circumference
2138.549952 Circumference (mm)
360 Degrees In a circle
5.940416533 mm per degree Divide circumference by degrees in a circle
1.4 Target total toe (mm)
0.235673709 Degrees Target divided by mm per degree
14.14042257 60 Multiply to convert to minutes
7.070211283 2 One half to determine minutes per side
I always use 1mm=.08 degrees.
1.4mm would be .112 total toe. no shop will hit that 100% on the mark though, so I always give ranges, like .11-13 total toe in this case.
You're making it too difficult. Use Inv tangent like Bill said. Or for totally mindless operation use this link!
https://robrobinette.com/ConvertToeInchesToDegrees.htm
Bill - my undergraduate degree is engineering so I've had a lot of math. Of course, I was studying trig back when slide rules were being used. I'm going to have to research your suggested approach. I may have understood it a long time ago.
Its very simple. there is NO conversion . as was said you need to use Trig. say you have the rim as the measuring point( front and rear ). you make a mark on the ground that reflect the front and rear positions. (or use the position of the rim to hold a string). then do the other side. the distance difference between the front and the rear of the the tires is the toe in or out. say its 1/4" ( 6mm) you take the 6mm and divide by the rim width (F/R) say its 18" (457mm) the toal toe is going to be 6/457 or 0.013 use INV TANGENT to get the toe in degrees which would be 0.74 degrees make it 1/8" that makes it .4 degrees toe (in or out) Out if the rear is wider than the front between the two points. and divide by 2 to get the toe of one side, which would be 0.2 degrees.
summary: difference of rear to front of rim to center or other side / rim width (f) INV Tangent = toe in degrees.
juanpablo046 (09-12-2022)
I dont follow your math... maybe for your 25" rims on the chevy tahoe! . if you re using the wheel edge as a reference point. Using the outer edge of the wheel of 18", 1.4mm toe, would be 0.17 degrees T-Toe and 1mm would be .12 degrees T-Toe.
Lets make it easy for the poor slide rule trained engineer.
See if the attachments help.
