987.1 3.8L Race Car ( FS )
Basic Sponsor
Forsale: 2007 Cayman S Race Car with 3.8L Motor
Cage :
1 1/2 Inch Roll Bar with .120 ID tubing ( Painted Silver )
IPD Plenum with GT3 Throttle Body
FVD ECU Upgrade
Fabspeed Long Tube Headers
Fabspeed Race Exhaust
Fabspeed Cold Air Intake
Motec CDL 3 with loggin
Brembo Club Race Brake Kit ( Front ) with RE10 pads
Giro Disc Slotted Rear Rotors
GT3 CUP Dual Master cylinders with Balance Bar ( ABS is still active )
Aasco Lightweight Flywheel Kit
Sachs Sport Pressure Plate
Sachs Race Clutch
Numeric Short Shift Kit
Numeric Shift Cables
JRZ 3-Way Dampers
Tarrett Front and Rear Adjustable Sway Bars
2 sets of 18 inch OZ wheels ( one mounted up with Michelin Rain Tires )
Cool shirt
Getty Carbon Fiber ( Cup Style ) Doors
Carbon Fiber Hood
Fiberglass Rear Hatch with Lexan Rear Windscreen
Getty Interseries Wing Base and wing with RS1 Cup Style Uprights
RS1 Lexan side Quarter windows with Driver side feeding the Heat Exchanger with fresh air
Getty Front Splitter
Quaife LSD
Cup Car Electronic Power Steering Pump
Lifeline Electronic Fire System with internal and exterior buttons
Electronic Main Cut-off / Relay
996 GT3 Front Lower Control Arms with Solid Thrust Bushins
Elephant Racing Rear Control Arms
Elephant Racing Rear Toe Kit
Toe Locking Plates
Rear Quarter Panels Flared and molded ( 1 inch )
RS1 Custom Alignment / Setup
Sabelt GT-Pad Seat with BBI side mounts, sliders and base.
Gear Box cooler
Note: This vehicle has not had any structure damage to any of the frame rails of the car. The only body panel that was replaced was the front trunk area floor due to a dent.
Cage :
FVD ECU Upgrade
Sachs Race Clutch
JRZ 3-Way Dampers
Cool shirt
Carbon Fiber Hood
Quaife LSD
Toe Locking Plates
Gear Box cooler
