Discovered an unfair advantage
We all know that the less unsprung weight you have, the better your handling will be. The wheels and tires are probably the biggest contributors to this unsprung weight. My race class has minimum weights for the wheels, and the tire sizes are specified, so I can't really do much there. But, what about if instead of filling the tires with nitrogen, you fill them with helium? Helium is a noble gas so won't interact with the tire rubber. The helium will make the tires considerably lighter. The only thing I'm worried about is when I take them off. Will they float away? I might have to keep them in the trailer.
I'm also thinking about installing tanks of helium in the car. That way I can run a lighter car. Then after the race, I open a valve and let all the helium out, so I can make my minimum weight at the scales.
You may want to revisit your high school physics classes.
You are assuming the "air" in the tires rotates? I use PTAS or Porsche Tire Air Stabilizer. This rarely purchased option keeps the air in the tires from rotating with the wheel/tires thereby reducing rotating mass. This is good for at least a few seconds on your PB at your favorite track.
I heard hydrogen is better than helium
