Brake pads for DE track for 2010 Cayman S?
I burn up Textar OEM pads in 2-3 track days.
What about KFP brake pads?
Performance Friction might be too much brake, and expensive.
Pagid gold? yellow?
My Cayman is also my daily drive, so I'd like to leave the pads on for the track season, and not have the obnoxious squeak from some track pads.
Suggestions?
Pagid gold? yellow?
Suggestions?
Not sure about 2010 Cayman S - we run 2003
Boxster S weighing 2600 lbs.
PFCs I find to be far superior to Pagid. We run the PFC08. Get about 24+ hours race time out of a set of pads. An excellent pad. The Pagid black have similar performance characteristics but don’t last us nearly as long.
With initial price being similar, the wear rate makes the PFC a better buy.
I do not believe this will be “too much pad” for you. Not at the curb weight of your car.
ETA: I see you are looking for a good set of pads for street / track. I’d recommend changing pads for track
use. If not, be prepared for some squealing from the pads when toddling around on street.
It is very likely you'll save money investing in a set of pads for the track and a set for the street. Any compromise pad is going to wear that much more quickly at the track.
I use pagid rs29 (yellows) which is the endurance compound and I get about 20 track days out of the front and even more from the rear. When I still daily drove my car I left the pagids installed on the street...the squealing doesn't bother me like most others.
RS29 Pagid here too. They work well on track and don't squeal too bad after track events. I've had them on since October for street use (last DE was November). I didn't drive the car much at all Nov-February though due to weather and temps.
I use Hawk DTC-60. They last long time on the track and are quite a bit less expensive than PFC or Pagid. They will make noise on the street but less than PFC (speaking from experience). I bought mine from autoanything.com
The design of calipers on our Caymans make it very easy to change pads. So, I would definitely recommend you to learn how to do that. Not only will you save money by swapping pads, you will also know exactly the state of your brakes before you get on the track.
2-3 days is real quick for pads..... unless you do many hours each day and drive very hard.
are the fronts wearing out faster than rears? (they should)
consider taking a look at driving style and whether you rely on traction control a lot....
There is no "free lunch". A few years ago I put Porterfield R4-S (high performance street pad capable of track) in my '88 911. They lasted exactly 3 track days before they were worn to the backing plate. I moved to Raybestos ST-43 (endurance race pad) on that car and then also on my track Boxster. On the 911 they howled on street so bad I had to swap them back and forth, this even after chamfering the leading edge and breaking them in properly. On the Boxster I keep them in full time, they did 10 track days during 6K miles last summer and are not even half worn, they work excellent cold and make 95% no noise on the street this time, why? no idea. Very powerful, no fade and wear like steel.
Not sure if they make in your size, but I tried Ferodo DS2500 on my 997RS and I was thoroughly impressed. The fronts and rears lasted approx 7-8 open track days, and the rears double that. They don't squeal too bad and held up when I drove on them. I drove in advance group if that helps.
With that said, I would opt for a dedicated track pad and dedicated street pad.
On my '12 Cayman R, I used Pagid yellow front/ black rear for several seasons and liked them. Longer life than oem. Currently using PFC11 and like them better. As for cost, when I look at the total cost of an event, the relative difference in pads cost is minor. Any track pad can be noisy on the street. For occasional use it doesn't bother me. For a car also used for DD, I'd just swap them out. On the 987, as others note pad swaps are dead easy.
Be mindful of the difference between 987.2 and 981 brake systems when considering pad advice. I ran Pagid Yellow front and Pagid Black back in the 981 and it was a good setup. With 987, I was advised the blacks were too aggressive and would cause ice pedal issues...
there are other pads that work well too, but the decision is more about wear rates, temperature performance characteristics, and dust when talking about DE/street use.
weight has nothing to do about the decision. well, it is a HP/weight ratio being the dominant wear/use factor, and as you gain more weight, the demands actually go down. (this is because when you are lighter you go faster, and its the KE that needs to be dissipated at the brakes to slow, so speed is the dominant factor, not weight)
yes, there is a free lunch.. pagid black RS14, and bed them properly. no squeal on the street if bedded properly (see my offer to provide step by step bed in procedure.... ive provided this to about 30 rennlisters)
