CGT owners, check your rear spoiler!!!
Old 05-06-2014, 04:27 PM
RS Clubsport
RS Clubsport's Avatar
Default CGT owners, check your rear spoiler!!!
After being very concerned about the high speed (mid three figure) handling on bumpy roads in my CGT, I've found a potential issue with the rear spoiler malfunctioning.
Over the last weekend I've had a warning on the OBD for 'rear spoiler malfunction' and when I've checked the spoiler, it's clear it's not extending fully on the drivers side. The handling traits have been exhibited since I started using the car this year in early April with no warning on the OBD.
This would explain why the car has adopted a corkscrew motion at very high speed, I've recently change to brand new Pilot Sport Cup 2 and the alignment was completed only a 1000 miles ago. It was a very unnerving sensation to say the least, and very glad I seem to have established the route cause.
Car is being collected and taken to Porsche Cars at Reading on Thursday and I'll report back in due course.
Just a heads up for people to check their rear spoiler is working correctly!!!
Cheers
Old 05-06-2014, 04:38 PM
JS
JS's Avatar
First I have heard of this.
Old 05-06-2014, 06:34 PM
wtdoom
wtdoom's Avatar
Matey I've had the fault light come up and not been able to move it around ( the spoiler).
I'm in the uk for couple weeks you around for a chat re the camber ?
Hope you are well
Old 05-06-2014, 07:42 PM
RS Clubsport
Hope you are well
All good Chief, around at the moment drop me a line we can catch up.
Cheers
JC
Old 05-06-2014, 08:42 PM
JEI-Porsche
JEI-Porsche's Avatar
the rear spoiler of mine has been repaired twice for the same issue. They first thought the hydraulic fluid was low but then found there was hydraulic leak of some sorts.
Old 05-07-2014, 04:45 AM
wtdoom
wtdoom's Avatar
Cheers
JC
Thank you sir , talk soon
Old 05-08-2014, 09:11 AM
W8MM
W8MM's Avatar
..., I've recently change to brand new Pilot Sport Cup 2
Sorry to hear of the spoiler issue -- will keep an eye on this thread to see what you determine.
On the Cup 2 subject, 265 Front & 325 Rear ??? How are they at speeds where the spoiler isn't in play?
Old 05-08-2014, 10:21 AM
RS Clubsport
On the Cup 2 I'm running 265 Front and 345 rear. The 345 has just become available and I've run PSS in 345 before with no issue (prior to the OEM 335 being produced).
Old 05-08-2014, 11:18 AM
W8MM
W8MM's Avatar
Oh happy day!!! I'm running 345 MPSS in the back as well. I like the small improvement in rear grip that 345 can offer. I can't wait until I can get them over here!
Old 05-10-2014, 12:32 PM
wtdoom
wtdoom's Avatar
John are they the correct profiles ?
Old 05-11-2014, 02:58 PM
RS Clubsport
Certainly are Baf.
Old 05-11-2014, 05:32 PM
wtdoom
wtdoom's Avatar
Certainly are Baf.
Oh that's just perfect . Perfect !
Didn't want to bother you over the weekend my friend ( and I was dying ) . I'll text you in the morning to get a good time to call
Hope you have been keeping well .
Old 06-07-2014, 01:28 PM
CGT000
CGT000's Avatar
I tried to raise the wing manually. It did go up all the way but gave me an error signal in the dash and the red light for the wing came on. Is there a malfunction with the wing?
Old 06-07-2014, 02:56 PM
RS Clubsport
Certainly sounds like it. The solution to the problem I had was to have the two rams replaced as they were not holding pressure.
Old 06-07-2014, 05:22 PM
CGT000
CGT000's Avatar
I just got the car from dealer. Supposedly they performed all services. I cant believe they didn't fix this.
Quick Reply: CGT owners, check your rear spoiler!!!
