CGT 2004 or 2005?
CGT 2004 or 2005?
Any major CGT mechanical improvement from 2004 to 2005? That is, improved clutch, engine, suspension, or transmission?
Any major mechanical or safety recalls for the 2004 models?
This has been asked and answered a few times on this forum, if you search for 2004 and 2005 you will see the other posts.
I was going to try and link them, but I am not sure how.
Thanks. I searched and received a few PMs. Apparently the most significant difference is that the paint and fit got better as Porsche produced more cars. You can see the carbon fiber pattern in the paint on the earlier cars, like you see on an F40.
Every panel is hand fit, so I don't believe they got any better in the fit either, they didn't redesign the panels so I am sure they all fit the same. I have never seen a difference between the fit and finish of any CGT, they have all been perfect. If you see any panels that don't fit or line up properly on a CGT my guess is it was in a accident and you should run from the car.
As stated in the other threads they added more options and colors in '05 and that is about it. I have driven a number of '05 CGT's and I can't tell any diffeence whatsoever.
I read somewhere an explanation from Porsche about why one can under certain conditions see the CF pattern through the paintwork - I think it was to do with ambient temperature (and probably lighting) - they said it was a feature and not a fault/problem.....
Like I said before I have never seen it on any CGT, but it certainly wouldn't bother me if you could see the texture through the paint.
Bill,
I'm not referring to orange peel but rather a distinct and repeatable weave pattern distinguishable below the paint. I would take a picture for you but a) I don't own a camera and b) the car is now entirely covered with clear film.
Josh
2005 CGT
2007 QP
Josh
2005 CGT
2007 QP
BTW, I understand there may be some later cars where you cannot see the weave pattern. Not that it matters to me... it's just interesting.
