GT + Targa at Laguna Seca
Nice pics Fayence, but I thought I had heard from another member of the rennlist that it was more difficult to control the car without the roof. Don't you have the same problem with yours ?
I'd suspect if you want to go 175mph+ then maybe having the roofs on might make a difference -- but having them off not only makes it easier to see and hear what is going on around you and give better hand signals, it makes the enjoyment 100x better -- just hearing that engine is everything!
I doubt that the handling would in any way be affected by having the tops off -- that monocoque is sooooo rigid.
In faster sweeping corners, especially with any crosswinds, the aerodynamic characteristics could be different enough between having the tops on or off to contribute to felt changes in high-speed handling.
I haven't had the opportunity to try out the differences for myself. The track session organizers around here have all required that I drive with the tops in place at their events.
Thanks for all your answers.
That's exactly what I wanted to know but apparently for most of you, you don't experienced these problems when you drive on tracks. So enjoy the sound of the V10 and I'll keep waiting to drive a CGT one day to experience it too when I be older (I'm actually 22)
Originally Posted by W8MM
It's the difference in aerodynamic conditions from top-on to top-off that's the issue. In faster sweeping corners, especially with any crosswinds, the aerodynamic characteristics could be different enough between having the tops on or off to contribute to felt changes in high-speed handling.
Interesting, here it seems that they prefer they be off.
Cabs and Boxsters have to run with their tops up, as well.
