Singer 4 Valve Air Cooled Engine
Have only seen magnesium heads mentioned in this article, which quotes the Singer ceo, Fawaz. But I guess I have seen plenty of articles misunderstand and print all sorts of inaccuracies
Quote from the article. Link— https://arstechnica.com/cars/2018/08...-f1-engineers/
””””””Fawaz says he had long thought titanium to be the ultimate choice for lightweight strength, but Williams' materials expertise taught him otherwise.
“At Williams, they have a display with aluminum, titanium, and magnesium blocks. It's incredible how much heavier titanium is than magnesium. This is where the F1 influence came in." It shows in the change from a two-valve to four-valve cylinder head, with Williams specifying magnesium for the job.””””””
First, Sumbaco above said that Singer used "magnesium cylinder heads". Is Sumbaco incorrect?
Second, I have no doubt that a small fortune was spent with Williams.
Third, clearly Chris Harris is a friend of and/or being compensated in some way by Singer.
Fourth, I have no doubt that everyone associated with Williams/Singer is serious.
Fifth, other than belief and logic, there is as of yet no concrete independent evidence of a long term successful test of the engine under extreme load. I do, however, very much hope it works.
Curious on a normal Singer, what is the drive train warranty?
I responded previously, but it looks like the comment got caught by a moderator for some reason. It's possible the author of the article I read misunderstood and wrote something wrong. It's not the first time that has happened, if it did. But the article quoted, or seemingly quoted, Singer CEO, Mr. Fawaz, saying that Williams chose magnesium for the four valve heads.
The article was on Arstechnica. It's still up if you google it. It's the only place if I've seen mention magnesium for the heads. I don't have any insider knowledge.
Quote from the article: It also uses magnesium extensively to reduce mass. Fawaz says he had long thought titanium to be the ultimate choice for lightweight strength, but Williams' materials expertise taught him otherwise."At Williams, they have a display with aluminum, titanium, and magnesium blocks. It's incredible how much heavier titanium is than magnesium. This is where the F1 influence came in." It shows in the change from a two-valve to four-valve cylinder head, with Williams specifying magnesium for the job.
The Article could be wrong. Or Mr. Fawaz might be wrong (particularly as it seems his knowledge of metals is limited). P.S. There is nothing new or revolutionary about magnesium -- it has been used for years by Porsche and many others (including many others not in F1) for years. Of course, given how it reacts to heat, its use in cylinder heads would be "interesting". Also, this could be just puffing. P.S. Many overplay the use of F1 technology.
Originally Posted by superquant
the DLS engine is designed and made by Williams, not Cosworth
the magnesium gearbox is Hewland's
i visited the Williams/Singer facility and it is hard to convey the level of seriousness that has gone into this project .. my anticipation is feverish and confidence total.
the test cars have been out and about for some time now, most recently
Mule 1
Magnesium fan
9000rpm Air Cooled 4 Valve masterpiece
Mule 1
Magnesium fan
Originally Posted by Robert Linton
I truly have not calculated this and will not until and only if we have a working engine.
