Macan Coding
#286
Hi, I'm back.
Simply put.
LKA and TJA are activated.
I use piwis 3 on normal mode. It can be used in our language.
Changing option is not necessary to use on engineer mode.
upper 2021 macan,It has fontcamera and LWA(Lane warning assist)...
so we can activate PDLS to PDLS + ,LWA to LKA,LKA with TJA(traffic jam assist)
We can activate LKA ,we select front electronic ,instrument cluster,front camera,gateway and power steering and F12 and first step select piwis coding and second step maual coding and select option code 6I1 LKA.
If you have safety driving,and select GJ1 traffic jams at the same time.
two safety options will be activated after coding.
First I drive LKA only ,It is used for the upper 65km only..and not used under 60km.
But with TJA,If you almost drive automatically and safely under 65km ...more than my Audi Sq5 FLY.
Macan acc is not activated on 0km but Sq5 is activated on 0Km.
I like macan TJA more than SQ5,but on stop and go traffic,I like Sq5 using ACC.
If you have question,I answer as much as possible.
Simply put.
any idea if this is possible with the Launch x341 as well?
#287
Big break through (IMO) for coding devices. Thinkdiag2 CAN do coding on our cars for around $130. If I understand these correctly, you need to renew the software license annually, but for those like me who really want to just code a few things in the instrument cluster, comfort window closing, etc... the one time cost of $130 is a whole lot cheaper than the $800 Launch devices.
The Thinkdiag2 when used with Android OS can do coding on Porsche cars up to and including MY2023, including my 2023 Macan. Now I only have a 2023 Macan to test on but it works just the same as the $800 Launch machines and uses effectively the exact same software. Note this will only work on 2023 cars (I think) with an Android device. I have both an iPhone and an old Pixel 3. With my iPhone the ThinkDiag+ software (Android and iOS) would only pull version 23.xx which was not compatible for coding on my 23 car. However on my Pixel using the same app the app in its software will download Porsche v24.2 which is the latest version that supports 23 MY cars
#288
Follow up questions
Hi, I'm back.
Simply put.
Simply put.
By following the instructions provided I was able to find the PDLS and TJA only. There was no LKA or LKA+TJA option. Maybe the newer soft has it…
Second, do you use a clone hardware? Can you share the link where you bought it from?
Also, when you’re coding, do you connect your car’ battery to some kind of power supply to keep the voltage steady?
#289
Hi, I'm back.
Simply put.
Simply put.
Anyone did it on model 2018 or before ?
I have only this :
#290
Hi, I'm back.
Simply put.
Simply put.
#293
[QUOTE=kapetajr;18085985]對於任何有興趣讓冷卻液壓力表讀取即時冷卻液溫度的人,請參閱此處https://rennlist.com/forums/991/1283...t-the-fix .html
我製作了幾天前我的 2015 Macan Turbo 也做了同樣的改變。
下圖顯示:儀表將顯示左側溫度,右側實際冷卻劑溫度。
為了修正這個問題,我將 X2 - X8 值複製到對應的 Y2 - Y8 欄位
和自適應煞車燈。如果汽車感知到 -81.gs 至 0.71 gs 減速度的減速度,則煞車會閃爍。
*煞車燈目前設定為閃爍 2 秒,但將減少至 1 秒。
[/QUOTE
]如何編碼自適應煞車?你能告訴我嗎?..plz
Sarum (03-29-2024)
#294
Last edited by WillinEvergreen; 11-16-2023 at 07:57 AM. Reason: found more pertinent reply
#295
Hi, I'm back.
Simply put.
Simply put.
I can't find any LKA options in the add-ons menu
Do I need to start PDLS to PDLS+ first?
Do I still need those settings?
#296
Has anyone been successful in modifying the coding for LKA, dash lights or adaptive braking, etc on a 2022 or later Macan. I have been told by multiple sources that Porsche has locked these codes down beginning in 2022. They tell me the codes are visible but can not be changed. This includes using PIWIS, Launch, etc.
if you have been successful please let us know what codes you were able to modify, what model and year, what equipment was used, etc.
Thank you
Thank you
#297
Vehicle data 6I1/6I3/6I8 Lane Keep Assist variant is applicable only for 2022 and up model year.
runbuh (12-03-2023)
#299
#300
