Macan 2014-Current
Water Temp reading
Old 07-16-2019, 07:38 PM
shaf
shaf's Avatar
Default Water Temp reading
Just picked up my 19 Macan S.. Water temperature reading is always 200 degrees. Oil temp seems ok. Any ideas?
Old 07-17-2019, 09:36 AM
Petza914
Petza914's Avatar
Received 6,172 Likes on 3,936 Posts
All water cooled Porsches newer than the 996 have a heavily buffered coolant temperature gauge, which means it doesn't display the actual coolant temperature. It's essentially an idiot light disguised as a gauge. If it ever moves much past vertical you have a problem. If you want to know your actual coolant temperature you need an obd2 monitoring system that will display it on a phone app or something for you. Coolant temperature will actually get as high as 215 F under normal circumstances, like sitting in traffic or climbing a mountain. Normal temperature should be in the 180-185 F range, like when cruising down the highway. Just use the oil temperature gauge as the indicator of what the engine temperature really is - use a good synthetic like Motul or Driven and anything from 175-225 F is OK.
rasetsu (07-17-2019)
Old 07-17-2019, 03:08 PM
Todd B
Todd B's Avatar
200 degrees on the dash is normal. As petza914 says you. Need an OBD reader that can read live data to see the real value.
Old 07-17-2019, 03:32 PM
CarGuyNVA
CarGuyNVA's Avatar
Totally normal.
Also note that oil temps will be roughly 8-10 degrees cooler in Sport mode versus normal mode.
Old 07-18-2019, 12:07 AM
wwahl
wwahl's Avatar
Originally Posted by CarGuyNVA
Totally normal.
Why is that? How would that be accomplished?
Old 07-18-2019, 12:39 AM
Todd B
Todd B's Avatar
Cooling is increased by opening the thermostat, and opening up the full cooling circuit. The oil cooler is oil to water cooler, the increased cooling with sport turned on, lowers the oil temp.
At least for the Pre 2019 Macan's, this is how the engine operating temp is controlled. (This is from the Service Information sales training manual)
Engine at operating temperature:
Both thermostat states (heating circuit and cooling circuit) are open when the engine is at operating temperature; the coolant can therefore circulate in both circuits. At an engine temperature of approximately 221° F (105° C), the heating current is adjusted correspondingly so that the engine setpoint temperature is maintained when the large cooling circuit is opened. When the Sport button is pressed or in the case of a very dynamic driving style, the engine setpoint temperature is reduced to 201° F (94° C). For this purpose, the heating current is increased significantly again to open the thermostat (large cooling circuit) further. The temperature at the radiator outlet increases when the large cooling circuit is opened.
Old 07-18-2019, 12:47 AM
wwahl
wwahl's Avatar
[QUOTE=Todd B;15980899]Cooling is increased by opening the thermostat, and opening up the full cooling circuit. The oil cooler is oil to water cooler, the increased cooling with sport turned on, lowers the oil temp.
Last edited by wwahl; 07-18-2019 at 12:49 AM. Reason: My question was answered above.I missread the answer.
Quick Reply: Water Temp reading
