5 broken valve cover bolts
I was recently looking at a used 2017 Macan Turbo at a non-Porsche dealership. The dealership had performed a safety check prior to putting it on the market and found oil leakage. I've read about the various oil leakage issues on Macans but the service report noted that the oil leakage came from 5 broken bolts on the valve cover. I haven't seen anything like this yet and this particular example only has about 12k miles left on the original warranty. Is this something to be concerned about long term? Or now that it's been fixed, is the problem resolved entirely?
I'm no tech. But non-Porsche shop? If I was the tech, I would have buttoned that engine up, and sent it to the Porsche store. They should not have touched anything if it were covered under warranty.
Don't explore, you'll get blamed.
Received 1,691 Likes
Funny how the picture in the OP shows the word “warranty” a half-dozen-plus times. There are simple, twisted, and conspiracy explanations for that.
As to the OP’s questions:
- you’ll never know why those bolts were broken. Young bolts typically break upon removal because they were over-torqued when installed. As a rule, bolts are not over-torqued at the factory.
- if it bothers you negotiate for CPO added to the remainder of the factory warranty.
In the original post above valve cover bolts are noted - not timing chain cover bolts.
There have been a few threads in this and other Macan forums about timing chain cover bolts and their failure
and associated oil leaks with the timing chain cover - not the valve cover(s).
Whether the repair to this particular Macan is an indicator of future issues, nobody can say for sure - and my
crystal ball broke years ago.
Who had the valve covers off and for what reason(s)? The bolts were apparently overtightened at that time.
While there are certainly many used Macans from which to choose, buying CPO from an authorized dealer would be
the safest bet. Why risk any other option? Price? If so, what would you really be saving and at what sort of gamble?
To give an update, the dealership (Stevens Creek BMW in California) ended up lowering the price to ~$58k over the weekend and someone else purchased it.
I believe this is a "bad bolt" issue my colleague had last year on his early 2017. It's an engine out job. Bad bolts or bad torque, porsche folks took photos of the fix process.
