Axle Re-Pack
Axle Re-Pack
All,
Time for new axle and was thinking of putting new blacks on the car to reset the hour clock. I would like to repack with Neo or Krytox, however, when I look at the inner CV joint, it appears to not be serviceable as the inner cover is crimped on.
Anyone know the trick on repacking the inner CV joint?
Christian,
You can cut it off to access it, or you can slide the boot over, carefully inspect, clean-up and repack.
We have all the parts, NEO, boots, bolts etc. here too.
http://www.demonspeedmotorsports.com/Driveline_c14.htm
