996 Cup Fuel Pump Out
I'm looking for the hose to allow a pump out / draining of a fuel cell in a 6Cup. I know it is a Sobek fitting and has a 996 P/N (I think in came in the spares with new cars back in the day).
Does anyone know either the 996. P/N or the Sobek P/N?
Pump out connector
I searched thru a bunch of the different PDF manuals I have and I found a part number for the pumpout connector in the 02 RSR manual (Item 9 in the picture) Not sure if it is the same as the later Cups
if you want to just pump out from the fitting by the filter in the engine bay then you can just get a local hose place to make you something up. its (from memory) rectus type 21 fitting and a length of fuel hose long enough to reach a jug. that fitting type is readily available, its used on air lines etc
