Rebuilding Cup BBS 3-piece Wheels - Easy or Hard?
Hmmm, need to check on the centers on that pair. Thanks for the tip Glen.
does anyone use the Dow sealant between the rim halves? I put a bead of it on the 4 I rebuilt, don't know if it's needed or not but it sure is tough stuff!
The thing is that BBS doesn't recommend using any kind of sealant other than the supplied gasket/O-ring. What you need to do though is tighten the bolts a little bit more when you have run the wheels for a session or so to avoid leaks. I've also been tempted to use sealant plus the O-ring but I'm hesitant now that they recommend against it.
