Porsche Cup Cars
993 RSR rocker arms
Old 03-14-2013, 06:16 PM
daedton
daedton's Avatar
Default 993 RSR rocker arms
Anyone have a lead on someone that might have some?
11 RS
07 RS
98 993 Cup
98 C2S
77 911S
Old 03-14-2013, 06:19 PM
KaiB
KaiB's Avatar
Check with Jeff Gamroth - Rothsport Racing.
Old 03-14-2013, 06:27 PM
mklaskin
mklaskin's Avatar
Non adjustable? I may have some from my old car.
Old 03-14-2013, 08:21 PM
Bill Verburg
Bill Verburg's Avatar
11 RS
07 RS
98 993 Cup
98 C2S
77 911S
W/ the RSR rocker arms you also need
x12 shafts 993.105.332.81
x24 studs 993.105.231.81
x24 nuts 900.817.001.02
and a wide assortment of caps from 2.6 to 3.7mm the caps are the same used in the early '70s RSR w/ 901 part #s
Old 03-14-2013, 08:25 PM
daedton
daedton's Avatar
Non adjustable.
Old 03-14-2013, 08:26 PM
daedton
daedton's Avatar
Thanks Bill. Yes all those too. Leads are greatly appreciated.
Old 03-14-2013, 08:37 PM
daedton
daedton's Avatar
993 gt2 rockers are an option too.
Old 03-14-2013, 08:57 PM
Bill Verburg
993GT2 Evo are the same as 993RSR, cams are different though
Old 03-15-2013, 01:13 PM
daedton
daedton's Avatar
Bill you have a lead on any?
Old 03-15-2013, 03:01 PM
Bill Verburg
Other than to give Joel Reiser or Jeff Gamroth a call, no
there aren't too may sources for these antique race parts any more and afaik PMS doesn't support the 993 anymore either though some of the suspension parts were available as late as last year so maybe give them a call too.
Old 03-15-2013, 03:22 PM
GTgears
GTgears's Avatar
Chris Cervelli, here in Denver, might know where to find those sorts of parts. Rodger at Orbit and Pat Williams also come to mind.
If you get really desperate I guarantee you can get them from Freisinger out of Germany, but expect to pay a premium price.
Old 03-15-2013, 04:03 PM
JoeMag
JoeMag's Avatar
Were those things not problematic back in the day? ...guessn your trying to keep original.
Old 03-15-2013, 06:39 PM
Geoffrey
Geoffrey's Avatar
You have several options. FVD has a rocker that works. It is a 993 rocker modified in similar fashon to the 993GT2 adjustable one and are PCA legal. Neil at Performance Developments can take a set of factory 993 hydraulic rocker arms and convert them to 993GT2 rocker arms.
The factory GT2 rocker arm uses a special adjuster that uses a Torx head with a 1.0mm thread pitch. The converted rocker arms "generally" use the standard 901 rocker arm adjuster.
I've run all of these rocker arms with no issues.
You can also try a 901 rocker arm with the splash lubrication hole pinned, however, these rocker arm tolerances vary quite a bit so you get varying amounts of lift and some of them have to be machined down so they fit inbetween the cam tower bosses. I've run these as well with no issue.
Basically, good luck getting anything out of PMNA that isn't 996, 997, or 991.
Give me a call if you need details on any of these.
Old 03-15-2013, 06:56 PM
Bill Verburg
He's looking for the cap type used on th 993RSR and GT2Evo, there is no screw adjuster on these
the shim caps are indeed 901 parts
Old 03-15-2013, 08:39 PM
daedton
daedton's Avatar
Thanks all. Geoffrey this is Joe Bank. You checked out my 993 Cup for me. You should see it now. Pretty much restored. Chris Cervelli is doing the work on this. It seems I have several options now and just need to acquire a set. Geoffrey if you ever make it out to CO give me a ring.
Quick Reply: 993 RSR rocker arms
