what makes 2010 Cup wider?
Picture is with smaller wheels for rain tires.
You can fit the new Michelin size (25 instead of 24) front tire with no changes (wheels and fenders). It works but there is not much room left. For the rear, the best way is to change in inner section of your BBS to fit the new size (30 instead of 28). There is plenty of room inside without any change to fenders or fender boxes. This is what we did on my 2009 Cup and it works very well.
Then you will have the same issue with understeer and front tire wear than the 2010+ cars have with the new Michelin ! ;0) I was using the previous sizes for 7-8 heat cycles before and now I can't do more than 4-5 HC with the new size. It looks like there is too much rear grip for the available front grip. I have to run the car with the front sway bar full soft and rear full hard + more fuel in the tank to add weight. But as I guess you expect, lap times came down significantly (1-2 seconds on a 1:40 lap track).
If you go on that path, you don't need a larger wing as you will end with too much rear grip anyway...
Thanks for all the useful feedback guys and I have learn alot in the process. BBS motorsport got back to me and they told me the 2010 Cup car have the following wheel specs
7.1 Cup 3 piece BBS wheels
front wheel
outer rim: 1" vs. 1.5" for 7.2 Cup
inner rim 8"
Rear wheel
outer rim 2.5" vs 3" for 7.2 Cup
inner rim 8.5" vs 9" for 7.2 Cup
So the 2010 Cup have the front outer rim width increase by 0.5" and rear outer AND inner rim width increase by 0.5" = 1" increase total per side which expalin the total width increase on the *** by 1.73"
As GT3 Techno suggested that you can just increase inner rim width on the rear to accomodate larger tire. 7.1 Cup front wheel can accept slightly larger 250/65/18 tire. So ... what will your Cup beheave on the track with larger front and rear tires? Let'st take a look at this chart below provided by Justin at Tirepro Flosom
much larger and taller rear wheel with 30mm increase in inner rim will increase offset by 30 mm = increase ride height and camber which will contribute to more understeer. There are number of things you can do to counter this effect such as soften front shock, raise front tire pressure and lower rear tire pressure, soften front sway etc. I am not sure why GT Techno experience drop in tire performance
0.5" on the inner rim will be enough to fit the larger 300/68/18 tire and really no need to go the full 1" increase. Inner rim cost about $550 each
I doubt that this helps very much, but in the photos you can see that my car retains stock bodywork. Glen's car has had the inner fender tubs worked on to allow the taller Michelins. I can't get the 710's to fit.
Talking to Glen is definitely a good idea.
Basic Sponsor
Mike, yes indeed your WC Cup has the stock bodywork, as we had a 3R Cup in here that was the sister car and it was stock.
In 2009 we widened the rear track and adjusted the wheel inner and outers for both the front and rear and updated the front fenders from the GA1 setup to the Cup S.
I have some bodywork left over for both versions as well as BBS wheels that fit the widebody front and rear.
We did run the bigger 12" rear with stock bodywork on the narrow body 997.1 but we had to adjust the inner and outer halves to make it work with the 305 Toyo we ran back then.
James F. Sofronas | President & Owner
Global Motorsports Group ™
E: james@gmgracing.com
P: +1 (714) 432-1582
F: +1 (714) 432-1590
A: 3210 South Shannon Street, Santa Ana, California 92704
W: gmgracing.com
W: gmgracing.com
