Gas shock adjusting tool
I am having a bit of trouble with the tool to add gas to the shocks for the Sachs shocks. The tool that I had worked great on my penske and the JRZ's, but on the Sachs, the schrader valve seems to be too recessed and I can not get the tool to tighten down on to it.
Where should I get the tool from that will work with the Sachs shocks.
Ed
Ed
Ed, I'm using this one with my JRZ's. I like it better than the "hose" ones because there is no loss when you unscrew it. http://www.proracestore.com/index.ph...oducts_id=4762
