Porsche Cup Cars
Auto blipper on sequentials
Old 02-10-2011, 04:24 PM
analogmike
analogmike's Avatar
Default Auto blipper on sequentials
HI,
I got to use my Manthey auto blipper at Sebring for the first time. it's adjusted per instructions, 25% throttle or something like that.
But in use, it does not seem to do anything. I'm still blipping the same, it will not get the revs up enough to downshift without manually blipping. It does help a bit with timing, if I jab it just at the right time it sounds and feels good.
I am thinking of upping the amount of throttle blip, any feedback on that? Does anyone use this with NO manual blipping?
The only thing I don't like is that you really can't shift into reverse when the engine is running, grinds too much.
Some in car video to see it in action:
http://vimeo.com/19769460
Old 02-10-2011, 09:28 PM
RSRRacer
RSRRacer's Avatar
Mike, I had one too and basically see it like you do. Seemed like it would blip but after I already engaged the prior gear so I essentially heel and toe the whole race.
Will probably get rid of it. Sucks.
Old 02-10-2011, 10:33 PM
nmercier853
nmercier853's Avatar
Mike I watched your "code brown" video and that was as close as it can get....all I thought of was carbon fiber/kelvar an under belly pans.
As for the autoblipper setup, TRG put one in the car for this past 24hr race because (2) of the drivers were very poor in understanding the concept of downshifting. The blipper was setup to rev to 6500-7000 rpm to help them. As a driver you still need to make the effort to blip the throttle but you have alot more room for error. Getting into reverse sucks it has to be quick, deliberate and push the pedal to the floor. People will look at you and think you are a retard reving the throttle for attention.
Old 02-11-2011, 12:10 AM
mklaskin
mklaskin's Avatar
Mine seems to work best when adjusted right up against the throttle. The instructions call for a 3mm gap between the throttle and the blipper, but that set up sucks. Get it right on the pedal.
From there, you can adjust the throw to give you more revs. It's not perfect...
Old 02-11-2011, 06:04 AM
Rickard 993 Turbo
Rickard 993 Turbo's Avatar
i have built my own version, best thing on the car...im just looking foa a used 996 cup abs then i will be super happy
Old 02-11-2011, 09:27 AM
Kuhlsport
Kuhlsport's Avatar
I ran one during Monday and Tuesday test days at Sebring as a trial. Took a little getting used to. If you are deliberate with the clutch timing, and delay your downshift until lower wheel speed, it works fine. If try to downshift too quickly, revs need to be much higher to match. I liked it. Allowed for more aggressive braking too. Agree is a PIA when need reverse.
Old 02-11-2011, 10:31 AM
Larry Herman
Basic Site Sponsor
Larry Herman's Avatar
Can't you have a cutoff switch when you want to select reverse?
Larry Herman
2016 Ford Transit Connect Titanium LWB
2018 Tesla Model 3 - Electricity can be fun!
Retired Club Racer & National PCA Instructor
Past Flames:
1994 RS America Club Racer
2004 GT3 Track Car
1984 911 Carrera Club Racer
1974 914/4 2.0 Track Car
CLICK HERE to see some of my ancient racing videos.
Old 02-11-2011, 11:15 AM
analogmike
analogmike's Avatar
Thanks for the feedback. Will try adjusting it closer and for higher revs and delaying the downshifting till I scrub off a bit more speed and see if that helps.
It's purely mechanical so no way to cut it off for reverse.
Kasey, did you try it with no manual throttle blips at all?
Old 02-11-2011, 04:25 PM
Kuhlsport
Kuhlsport's Avatar
I did not do any manual blips once I got the timing down. Initially my wheel speed what too high for the blip we had set so gear engagement was chunky and rough. We increased the throttle setting and I delayed my downshifts more and it was good. I will tell you, it allowed me to put total focus on initial brake pressure without concern about getting the blip done with my foot. Over the course of a 45 minute run, the fatigue factor was less as well. You can just plant you heal on the floor board after initial brake application. Holding my heel out to blip makes my right hip sore after a long run.
Old 02-15-2011, 10:43 AM
JR944
JR944's Avatar
Hi Mike,
I have a coaching client using one in his '06 Cup. He doesn't heel and toe at all. Initially set blipper lower, but now around 35% throttle and working well for him.
Sorry I missed saying hello at Sebring.
Joe
Old 02-16-2011, 11:35 AM
analogmike
analogmike's Avatar
Thanks for the info.
Joe and Kasey, do you kill the engine before shifting into reverse? Mine grinds and won't go in when the revs go up shifting into reverse. I found some metal flakes in my tranny oil after the race but I was very careful on the track, my guess is that it's from reverse...
Old 02-16-2011, 06:55 PM
Kuhlsport
Kuhlsport's Avatar
I think I only used reverse one time that weekend. I know the car was running. It didn't seem like a problem. You should just go forward from now on!
Old 02-17-2011, 01:21 PM
analogmike
analogmike's Avatar
Good idea, it was happening mostly at our paddock so after a few sessions I gave up and just hopped out of the car and let the mechanics push the car backwards under the awning so I didn't need to use reverse.
Old 02-17-2011, 01:42 PM
mklaskin
mklaskin's Avatar
Mike,
Let us know if you notice any improvement. I'm always curious if mine is optimized.
Thanks.
Old 02-17-2011, 02:01 PM
Larry Herman
Basic Site Sponsor
Bet you could come up with an e-gas cutoff switch that would ignore the throttle input and keep it at an idle while you put it into reverse.
Quick Reply: Auto blipper on sequentials
