What is flywheel sensor gap spec (recessed sensing wheel)
What is the sensor / flywheel gap spec for the cup/rsr flyhweel with this recessed crank sensor ring? For anyone running motec (M48Pro in my case), do you see much need for adj beyond that spec? Reason I ask is that with sensing gear in stock loc'n (out by starter ring), you can adj and fit some type of feeler gauges in there if there's an issue. However with this, not really sure how you gauge any adjustment after motor/trans are mated.
I use the stock specification of .8-1.2mm so I end up setting it at 1.0mm. From time-to-time we see instances where the sensor produces too much voltage for the M48 at higher RPMs and we need to space it out with a washer. It will be readily apparent on the dyno if there is an issue.
