04 gt3 cup set up for sebring ?
first time at sebring with gt3 cup, looking for info on set-up.
running dunlop gt tires f-235/640/18 r-280/660/18
cup springs and sachs shocks
f&r sway bar adj? shock pressure?/rebound-damping?
If you have stock springs and shock..... then the front sway bar on a 6-cup should be welded at 1-off full stiff. For the rear bar I always start out my first session at 1-off full stiff with the intention to move to full stiff once I get myself and the car in sync.
IIRC Sebring is bumpy so I would set my shocks a little soft for compression, maybe 15 out of a possible 40 (hard). For rebound, a middle position maybe 5 out of a possible 8 (hard).
I would keep the pressures down a bit, 60 front and 180 rear. Remember to account for pressure loss in your gauge's hose unless you have a shut off at the cannister. YMMV....
thanks for the info,i'll give it shot.i like the idea of a shut-off valve
at the cannister! would this be on the cannister x-4 or on
the hose of tool? where to pursche?
Here's link to a thread you shoud read, especially the last page: https://rennlist.com/forums/racing-a...pressure+gauge
Don't the stock Sachs dampers have the issue of the valve stem that is too short for most guages? If your's haven't been modified with longer stems then I would try this gauge.
http://www.ccrsport.com/index.php?ma...roducts_id=225
It's the only one we found that works on the short stems.
Best,
Doyle
Not to change direction on your thread, but if you run Dunlops regardless of setup you will be leaving alot of time versus michelins.
I am not sure of your skill level but you would be leaving maybe a full second a lap at Sebring. Thats tough to overcome.
CB
CB
