2009 Cup Car
Basic Sponsor
We have cars available if anyone is interested.
GMG
714-432-1582
Fabryce Kutyba
Co/Owner VP
GMG
714-432-1582
Fabryce Kutyba
Co/Owner VP
sales@gmgracing.com
www.gmgracing.com
714.432.1582
facebook l instagram l youtube l twitter
Porsche | Audi | Ferrari | Lamborghini | McLaren
Performance Tuning | Motorsport | Factory Service
Pirelli World Challege Race Team GT/GTA/GTS/TC
Pirelli GT3 Cup Trophy USA
Porsche Motorsport — Audi Sport Customer Racing — Lamborghini Super Trofeo Series
sales@gmgracing.com
www.gmgracing.com
714.432.1582
Details are available now.
Normal GT3 cup is about the same as 2008.
Brakes are no longer floating disks?
The Rolex GT3 cup has a new carbon fiber front end, comes with the wider front fenders and no rear wing (you get it from crawford). Also adjustable trailing arms front and rear. 10 and 12" wheels. A tad more power officially 428hp / 424NM torque (wonder if they will have more as raced?).
The wide fender looks similar to the Cup S from Europe????
Page 2 of 5
911 GT3 Cup
Model Year 2009
Vehicle Description / Technical Specifications
Concept: • single-seated, near-standard race vehicle in accordance with the 2008
Porsche Manufacturer’s Cup Regulations
Engine: • naturally aspirated engine
• water cooled flat six-cylinder boxer engine
• 3,598 cc; stroke 76.4 mm; bore 99,98 mm diameter
• max. power: SAE 420 PS
• max. torque: 420 Nm
• max. rpm: 8,400 rpm
• four valves per cylinder
• dry-sump lubrication
• four-stage resonance intake manifold, central inlet air duct
• electronic engine management system MS 3.1
• sequential multi-point fuel injection
• required fuel quality: 98 octane ROZ, unleaded
• race exhaust system in modular design (with or without pre-silencer)
• lambda-probe-equipped catalytic converter (400 cubicles)
• twin-branch center exhaust tailpipe
Transmission: • six-speed sequential dog-type gearbox
• gear ratios:
bevel crown wheel 8/32 i = 4.000
1 st gear 12/38 i = 3.167
2 nd gear 15/32 i = 2.133
3 rd gear 18/31 i = 1.722
4 th gear 20/28 i = 1.400
5 th gear 23/26 i = 1.130
6 th gear 29/27 i = 0.931
• pressure-oil lubrication
• oil-water heat exchanger
• single-mass flywheel
• hydraulic clutch center-release mechanism
• 5.5“ triple-disc sintered-metal clutch
• limited slip differential 40/60 percent
• rear-wheel drive
Bodywork: • self-supporting body shell made out of galvanized sheet steel
• aerodynamically optimized front bumper and front spoiler edge
• carbon fiber doors with window frame and plastic rear-view mirrors
• carbon fiber rear lid with adjustable rear wing
• carbon fiber rear bumper
• air jack system
• reinforced welded-in roll cage
• racing seat (driver side only) with fire retardant upholstery
• six-point seat belt optimized for use with HANS system
• removable steering wheel (with quick-decoupler)
• electric fire extinguishing system
• 90 liter fuel tank
• safety retainer for battery retention
Suspension: Front axle:
- McPherson strut-type axle
- Sachs gas pressure shock absorbers
- double coil springs (main spring and helper spring)
- two-piece lower control arms for camber adjustment
- blade-type anti-roll bar
- damper mounted to upright with twin-clamp system
- power steering with electro-hydraulic pressure feed
- forged supporting mounts
Rear axle:
- multilink rear suspension with solidly mounted sub frame
- reinforced, continuously variable rear axle track rod
Suspension continuously variable (height, camber, track)
Brake System: Brake system with adjustable bias bar
Front axle:
- aluminum six-piston calipers, single-piece, steel brake discs with
aluminum pot, 380mm diameter, race brake pads
Rear axle:
- aluminum four-piston calipers, single-piece, internally vented brake
discs, 350 mm diameter, race brake pads
Rims/Tires: Front axle:
- three-piece BBS center-lock aluminum rims (9J x 18), rim offset 43
- Michelin rain tires (24/64-18)
Rear axle:
- three-piece BBS centre-lock aluminum rims (11J x 18), rim offset 30
- Michelin rain tires (27/68-18)
Electronics: • Motec display with integrated data recording
• battery: 12 Volt, 50 Ah
• 90 Ah generator
• PMNA highly recommends the installation of a Bosch data recorder
(Part# 996 618 709 9A) to assist with analysis of engine and
transmission metrics.
Vehicle Weight: Approx. 1160 kg
Vehicle Measurements: 4444 mm x 1810 mm x 1300 mm (length – width – height)
Color: (Water-based paint)
• Exterior: Carrara white B9A
• Interior: white filler-coat, no clear-coat finish
Importation/Transport: All cars will be transported by air (i.e. Lufthansa, British Airways); import and
transport costs will be charged to customers directly by the Porsche
logistics company, Kroll USA; ballpark price: approx. $16,000 per vehicle,
subject to change (depending on fuel costs and available cargo space.)
Conformity with
Regulations:
The vehicles will be delivered in their basic version in accordance with the
2008 Porsche Manufacturer’s Cup Regulations. Each customer is
responsible for his car to fully comply with these regulations.
All data provided by Porsche/PMNA as of October 2008 and subject to
change without prior notice. All previously published technical data is no
longer valid.
***Vehicle cannot be registered for public road use***
911 GT3 Cup
Model Year 2009
• gear ratios:
• rear-wheel drive
• air jack system
Rear axle:
Front axle:
Rear axle:
Rear axle:
• 90 Ah generator
Conformity with
Regulations:
longer valid.
Platinum Dealership
the cup S front bumper wraps all the way around and flares off the side of the wheel arch. it's a really wide body car. like a CTR2, or a 935 or something.
here is a picture
http://www.zcars.com.au/images/porsc...gt3-cup-s1.jpg
http://www.911uk.com/images/news/997CupS5.jpg
notice the different exhaust outlet- more like an rsr
the regular cup cars are narrow body.
here is a picture
CJ: Thanks, but I was inquiring as to the photo analogmike posted of the Rolex GT3 cup which is wider than the standard cup and looks near identical to the Cup S, if not the same. I looked at the pics of the Cup as compared to the Rolex GT3 and was trying to see if there is any difference to the front at all. From what I can tell, the Cup S front splitter may come down slightly lower than the Rolex car, but I am not sure.
Platinum Dealership
sorry- the Cup S has a thin, flat shelf chin spoiler and bumper is taller, reaching down lower towards the ground. I'm not sure what rolex is running next year, my general aim is more towards the imsa cars and RSR stuff which I'm more familiar with. I don't really follow grand am stuff as much, nor do any of the teams that I have contacts with race there.
the chin spoiler of the regular cup cars were all the same last year- it's a 138 dollar part from PMNA. you were able to order it either with or without brake ducts- very similar in appearance to the GT3 street version, just taller. the above picture integrates all of it into one piece- which to me means a lot of people will be buying bodywork!
the cup cars I saw in weissach recently were all IMSA spec with the standard narrow front end and waiting for the plastic chin spoilers to be installed. it looks a bit different from last years part however.
