New Helmet Paint Job
Well white it out and color is in - lets see yours!
JCM
JCM
GT3 player par excellence
whip helmet is that? GP5w with visor?
Super Moderator
Needs More Cowbell
Needs More Cowbell
FWIW, I was told that putting your blood type on the helmet and/or suit is a bit of a waste. They said in an emergency it is not used.
(same thing was said regarding my son and karting....we put it on anyways).
The above is true -- you would be tested for blood type in the emergency room regardless of what your suit, helmet, or medical form says. That said, I have it on my helmet as well. Typing errors do occur occasionally, and I'd like to think that they might check twice if the lab disagrees with what's printed on my helmet.
Outstanding
Don't know if it still is required.
Your helmet doesn't go to the blood bank to confirm your blood type when they do the cross match. Your helmet will get thrown on the floor and/or stuffed in a belongings bag as they cut off you suit in the trauma room. Your blood type is much more than a simple ABO rH that most lay people think of. The rules need to reflect reality. Done with the soap box.
Nice helmet!
It has put a fire under my butt to get mine to the local paint shop.
Nice helmet!
he's right, no way they will go off your helmet. that's for TV shows
in fact, if you think you're getting typed and cross-matched any sooner than the better part of an hour, you're mistaken
it fluids and expanders in the ER. that will keep you a long time, unless you're DONE. in which case it will keep you forever
SCCA, are you listening!?
